Navi system colors?
Discussion in 'Gen 2 Prius Audio and Electronics' started by townpoets, Jan 8, 2007.
  1. townpoets
    townpoets New Member
    I have an 05 prius. I know that the navi system has a "clock" and it has a daytime mode and a nighttime mode where it darkens the screen and changes to darker colors. I was wondering if there was a way that the system could do it automatically. I was driving a van from toyota with the same navi system and it changed to nightime mode without me doing it. If there is a way could someone help me figure it out. I know that if u adjust the light dimmer switch on the left hand side but that is difficult to do while driving in traffic.
  2. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
    It should only switch to night mode when you turn your headlights on. There's a setting, I believe, that allows it to always stay in day-time mode as well.
  3. townpoets
    well i alwayz drive with my lights on all the time to help visibility. ill look through my menus to see if i can find a all daytime mode . but i want an automatic one. anyone else messed with those settings
  4. qbee42
    3,079
    <div class='quotetop'>QUOTE(townpoets @ Jan 8 2007, 12:59 PM) [snapback]372527[/snapback]</div>
    On the 2006 model, the MFD will switch to daylight mode if you roll the dash dimmer wheel all the way to the brightest setting. You can also select daylight mode from the display menu of the MFD. I don't know the details of your model year.
  5. IsrAmeriPrius
    IsrAmeriPrius Progressive Member
    4,333
    Southern California
    <div class='quotetop'>QUOTE(townpoets @ Jan 7 2007, 10:50 PM) [snapback]372371[/snapback]</div>
    Did it have automatic headlights?
