Where to Buy OEM Wiper Inserts
Discussion in 'Prius v Accessories and Modifications' started by prevee5, Sep 17, 2024.
  1. prevee5
    prevee5 Member
    121
    Monrovia, California
    Best source for Toyota OEM wiper inserts for Prius v?
    Local dealer wants $16/each. Not installed
  2. rjparker
    10,138
    6,300
    You can buy them for half the price from an online Toyota dealer. Try to find a local dealer online that allows local pickup.
    Brian1954 likes this.
  3. Tombukt2
    12,957
    2,325
    They have been covered in the aftermarket before I don't think only Toyotas have to be used trico and a few other companies probably have you covered I know I've put new inserts and Bosch hybrid wiper assemblies before the rubber part It's not really hard to do takes about 2 minutes aside so it can be worked around I don't have all the part numbers in front of me I exclusively use on all of my vehicles the hybrid wiper blade looks like it has an armadillo shell over the rubber that is all I use I don't use any beams or any of that nonsense I have when they first came out they don't last that long they float things go on with them they squeak a lot or make wiping noises whereas the hybrids I have not had the problem doesn't matter who makes the hybrids Rain-X Bosch and a few others make the hybrid armadillo covered assemblies I've been using these about 10 11 years now and that's all I use so I can't tell you about the beams and all the other business I have changed the rubbers on Bosch icon beams quite a few times with Bosch's own replaceable inserts made for other style wiper assemblies but made by Bosch that's all I can tell you here in North Carolina the replacement business for my 2010 we're only like 799 a piece at the dealer walk-in matter of fact I think they even offered to put them on for my girl I don't remember but she went over she was trying to do everything right with the 2010 vehicle and keep it natural and nice or whatever folks call that so she wasn't having any of the wiper blades and nonsense I was putting on my Prius. She was going to get the real thing and she did and that's what they cost.
  4. BiomedO1
    3,585
    1,856
    SacTown, Ca
    I bought a roll of commercial bus silicon wiper blade refills and just cut them down to size. I think my wiper blade refill are different from yours; my neighbor's 2019 Camry doesn't fit my universal blade refills. I buy them online, starting with the OEM part number and drill down from there.
    Hope this helps
  5. Mendel Leisk
    41,424
    I got the Toyota wipers for our ‘10 through Amayama, good price. Do check with dealership too; sometimes their prices are decent.
  6. Air_Boss
    Air_Boss Senior Member
    4,197
    1,183
    New Yawk
    I use one or two inch longer Valeo beam/bracketless wipers for a larger cleared area, left, right and rear.
  7. rjparker
    10,138
    6,300
    For my v wagon I have maintained the oem aero blades using inserts. Just recently at 300,000 I replaced the arms because one became weak. I used Hoover Toyota online in that case as the spring loaded arms were a little pricey. At the time I replaced the blades as well simply because the paint was worn off.
    Toyota v wipers insert part numbers:
    85214-47061
    85214-47051
    Rear
    85214-12310
    Blade, Front Wiper, LH 85222-47040
    Blade, Front Wiper, RH 85212-47060
    Blade Rear Wiper 85242-12090
    Arm, Front Wiper, Rh 85211-47140
    Arm, Left Wiper, LH 85221-47120
  8. prevee5
    prevee5 Member
    121
    I did just that. The same dealer that quoted me $16/each at the counter had them at around $8/each online with free pickup. Go figure
    TGrracie and Tombukt2 like this.
  9. rjparker
    10,138
    6,300
    Like everything in life, you need to know how to play the game.
  10. Tombukt2
    12,957
    2,325
    That's right you go online to Toyota.com or whatever and you order them there for half or a third price and then you have them sent to where you want to pick them up down the street from your house whatever the name of the place is and then you don't have to pay any shipping or any of that because it's going right to a well Toyota people dealer whatever it is and that's how you play the game now used to be you did it with the telephone now you do it with the PC social media and whatever you call it you know the website got to go to the website that's all anybody can do now Tell you to go to the website No one can tell you anything all they can say is go to the website ask somebody which way is the bathroom they'll say Go to the website and ask marvelous
