... per capita lifetime household H2O consumption, 109k gallons?
Discussion in 'Fred's House of Pancakes' started by asjoseph, Sep 13, 2024.
  1. asjoseph
    asjoseph Samuel, '04 Ruthiemobile
    91
    30
    117
    lancaster, california
    49,906
    it's a good thing they save all that water on other car fires, so it's a breakeven
    fuzzy1 and Trollbait like this.
  3. rjparker
    8,340
    4,954
    Water is a renewable resource.
  4. ChapmanF
    16,127
    the more tesla semis on the road, the more other cars we'll have to start torching, to be sure of saving enough water
  5. Mr.Vanvandenburg
    1,185
    423
    2020 Prius Prime
    Lithium ion is safe, so safe.
  6. Trollbait
    11,718
    It's not like ICE fires can cause extensive damage, or the lighter than water, burning fuel can flow elsewhere.
  7. bwilson4web
    15,630
    I had an overloaded 12 V battery almost strand my wife and I in the middle of a no-shade, parking area. I spied the early smoke and popped the ground off just in time. A couple of hours later, reconnected and we drove home.
    #7 bwilson4web, Sep 14, 2024
  8. Trollbait
    11,718
  9. MAX2
    MAX2 Member
    371
    88
    Third Rock from the Sun
  10. Trollbait
    11,718
    Car sized blankets for smothering EV fires are already available.
    Nozzles are being developed to spray under the cars to cool the battery packs more directly.
    Then some locations will do what they used to do to old VWs with burning engines; bury them.
    This is a temporary issue.
  11. bisco
    49,906
    has anyone ever attempted to put out an elephant fire?
  12. ETC(SS)
    6,610
    "consumption...." (non pulmonary tuberculosis.)
    noun
    1. the using up of a resource.
    You can "use up" water?
    Where does it go? ;)
  13. tochatihu
    tochatihu Senior Member
    9,107
    3,545
    Kunming Yunnan China
    2001 Prius
    Global hydrological cycling explains where water goes. A fascinating topic I say and maybe it deserves a summary in a more appropriate place. Most briefly the fraction of terrestrial water returning to salty places is used up. But that is not a permanent fate.
    Here is for telling sad tales about EVs. See what sticks to the fridge.
  14. bisco
    49,906
    usually childrens coloring, which sums up the op
  15. fuzzy1
    10,308
    I wonder where that claim came from. It works out to about 3.8 gallons per day (gpd), for a pre-Pandemic average life expectancy of 78.8 years. That is an extreme under-representation. Less than a single flush of some old-era toilets.
    Several sources suggest that California's per capita urban indoor water use is about 48 gallons per day. I'm seeing other sources including urban outdoor use, range from 69 to 146 gpd recently, down from 231 gpd back in 1990. If all uses are included, including agriculture, it rises to almost 1000 gpd.
