Is it possible to fix this without taking the front apart?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Scott_R, Sep 23, 2024.
  1. Scott_R
    Scott_R Member
    434
    Long Island
    2024 Prius Prime
    IMG_9041.jpg I don't know if it'll snap in place, but I don't know how to access the back of it without some disassembly. I tried attaching a suction cup to it and pulling it forward, but obviously this didn't work. I don't have tools beyond the basics (Superstorm Sandy destroyed tools I'd spent years putting together), and if I suddenly need a part to put things back together, I don't have a second car to run out with.
    It's been like this for some years now.
    #1 Scott_R, Sep 23, 2024
    51,901
    what is it?
  3. Scott_R
    Scott_R Member
    434
    Long Island
    2024 Prius Prime
    Sorry, attachment didn't upload; fixed.
  4. BiomedO1
    3,585
    1,856
    SacTown, Ca
    It's the fog/marker lamp assembly. I think it's accessible by getting behind the splash guard. Try putting it on a ramp to see if there's an access cover from underneath.
    I removed my entire front bumper cover on my old Prius C to push out a dent and replace the marker assembly. A rock hit that marker dead center and spiderweb it. Pieces started falling out a year later. The bumper cover mostly just snaps together, so not breaking the snap tabs is very important.
    Hope this helps.
    I hate the AI auto correct!!!!!
    #4 BiomedO1, Sep 23, 2024
  5. ASRDogman
    ASRDogman Senior Member
    7,575
    3,906
    You should be able to remove the splash shield and take a look at it.
    The wheel well splash shield.....
    There are only clips holding it on I believe. I'd look, but it's raining here right now.
    #5 ASRDogman, Sep 23, 2024
  6. Mendel Leisk
    41,425
    I would just follow your nose; at the underside at the corner there's a push-in plastic fastener, a screw and a bolt (10mm bolt head for both of those). Then go a little further, removing fasteners from the first black plastic piece directly behind the front fairing, and a few of the wheel well liner fasteners. For the latter there's one just up a bit, on the outer edge, has a slot for screw driver you need to turn 90 degrees to release.
    It would be good to have the front up a few inches.
  7. Tombukt2
    12,957
    2,325
    Try and use a flat narrow scraper or a butt or knife and see if you can get it to sit in its place that way If not you got to take off that nonsense behind it so you can well access it and then you'll see what holds it on what clips are broken or whatever
