My Yaris hybrid emits cleaner air than it inhales in terms of PM
Discussion in 'Environmental Discussion' started by alexeft, Sep 22, 2024 at 5:25 AM.
  1. alexeft
    alexeft Member
    142
    Greece
    Surprise surprise! I measured emitted particles at the exhaust of my Yaris hybrid and it emits less than there are in the air around it!
    I guess you could say that it actually cleans the air as you drive! ;)
    Melon Musk, you are sooooo behind! Your cars only emit less. They don't actually clean up!
    Now, go play with your rockets! We'll keep the planet to ourselves! (y)
    PS: I will post pictures later on!
  2. bwilson4web
    15,596
    Not quite accurate as we have exceptionally efficient, cabin air filters. To avoid the noise and stink, we tend to drive with our windows up and change our cabin filters frequently.
  3. hill
    8,289
    Let's test your theory about how your car cleans the atmosphere. Buy yourself a canary, put your car in the garage with the ignition running & idling overnight & all garage doors closed - canary in garage. Then try the experiment with an EV turned on in a garage & see who is the 'winner' is.
    Enjoy your car .... it's a fine car - but don't ever think that it's exhaust is sunshine & laughter of little children.
    #3 hill, Sep 22, 2024 at 11:11 AM
    Trollbait likes this.
  4. alexeft
    alexeft Member
    142
    Greece
    I wrote that it cleans the atmosphere in terms of particulate matter people.
    Not that it emits oxygen too.
    Of course the canary would die.
    But a Tesla car or any electric does not gather PM at all.
    Also, I have an exceptional cabin filter too and I drive with the windows up all the time! I still want my life!
  5. hill
    8,289
    EV's didn't put particulate matter into the air in the 1st place. Then again, shouldn't you count the refinery burning fuel to convert into the various products? Then again, both diesel, gas burners as well as EV's output particulate from rubber tires. All 3 transportation forms put out particulate in the form of brake dust too . That batch of extra fun facts kind of makes the whole point mood - in essence. At least EV's can generate fuel at home via PV solar. So they don't necessarily have to get credit for the refineries. Can't do that with a gas burner, not even if you build a refinery in your garage
  6. alexeft
    alexeft Member
    142
    Greece
    Thankfully enough, we (almost) don't have refineries inside cities! :(
    We only have cars!
    As for generating fuel at home, I don't care. I that car uses little of it, there is no problem.
    And if I buy from reputable companies (which I do) there are no quality issues either!
    Why bother with the whole ordeal and lose an opportunity to do a little cleaning up?
    (y):LOL:
  7. bwilson4web
    15,596
    How?
    I'm interested in both the equipment and testing protocol. For example, what temperatures, speed, and duration.
    hill likes this.
  8. Trollbait
    11,685
    Diesel cars with exhaust filters have been cleaning particles out of the air for decades now. Still wouldn't want to breath that exhaust directly.
    Is the Yaris new enough to have an exhaust filter too?
    Are the particles removed enough to counter the particles coming off the brakes, tires, and road?
    wxman, fuzzy1 and tochatihu like this.
  9. tochatihu
    tochatihu Senior Member
    9,081
    3,538
    Kunming Yunnan China
    2001 Prius
    This is an interesting comparison and not well explored yet I guess. EVs (and hybrids :) ) shed less brake dust because of regenerative braking. But they are heavier and probably shed more tire dust.
  10. fuzzy1
    10,283
    What were the ambient PM levels in your area? Levels vary enormously by location.
    EVs don't have tires? :confused:o_O
  11. hill
    8,289
    of course - & that's why it's already mentioned - in the very post that raised the question.
  12. Trollbait
    11,685
    Modeling says the extra weight will result in more particles, but then the data for the model came from studies involving commercial trucks. Being boxy things, they have turbulent wakes, and the studies didn't differentiate the particles in the air between what came off their tires and what got resuspended from the road surface by their passing.
    The new EU emission regs will be imposing limits on particles from brakes and maybe tires.
  13. tochatihu
    9,081
    3,538
    2001 Prius
    Repeated measurements with tread-depth gauge would provide upper limits on shredding fluxes. Re suspension of road surface stuff would not matter. Nor would troublesome aerodynamics in the vicinity.
  14. Trollbait
    11,685
    Won't tell you the size of the particles, or if the rubber isn't adhering to the road surface.
  15. hill
    8,289
    Actually a combo of both tread depth as well as tire circumference ... giant wheels coincide with very heavy vehicles. Many interstate haulers go through tires in as little as 3 years.
  16. wxman
    wxman Active Member
    623
    224
    Tennessee
  17. bisco
    49,822
    what is an exhaust filter?
  18. Trollbait
    11,685
    For particle emissions. Diesels have had them for a awhile; called a DPF. The regeneration cycles diesel cars do is to clear off the filter.
    Some gasoline engines make enough particles to require them under US regulations, but are exempt from needing them. Europe now requires such to have the filters, and you'll see GPF used for them.
    The dual port and direct injection Toyota uses was an effort to avoid needing the filter. Don't know if that worked, but the new engines coming out are just direct injection.
    wxman and bisco like this.
  19. hill
    8,289
    picked up a Sprinter diesel class C motorhome on the cheep - upon retiring 4 years ago or so, it was necessary to refresh my diesel knowledge. Much has changed since the very early 1990s regarding diesel emissions. Who would have ever thought back then that putting urea into exhaust could remove much of the particulate. Who would have ever thought it would require a heater for -11C° winter temps -
  20. bwilson4web
    15,596
    Still wondering how a Yaris hybrid takes particle metrics on the air intake and exhaust?
    Lasers and cameras?
    hill likes this.
