Replacing water pump rotor vs entire unit
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Matt98svt, Sep 22, 2024 at 10:35 AM.
  1. Matt98svt
    Matt98svt Junior Member
    64
    South Carolina
    2015 Prius v wagon
    What are your thoughts on replacing the water pump rotor vs replacing the entire unit? I just picked up a 2012 that im doing the head gasket on and was going to order another aisin unit ($150 from amazon) but saw a post about how the the electronic side of these pumps almost never fail since it doesnt really have any moving parts and that its the rotor that actually swells or comes apart and just to replace that part. I ordered one from amazon for around $20 and it does look identical to the factory and drops right in. Thoughts? Anyone had a water pump fail from the electronics?
  2. JC91006
    JC91006 Senior Member
    16,500
    8,412
    If you already ordered one, just install it and give it a go. I put one on my car with 215k miles and it still working nicely. It may not last the 150k miles that an original part can last, but you can replace it next time you drain/refill your coolant again.
    Matt98svt likes this.
  3. ASRDogman
    ASRDogman Senior Member
    6,292
    3,354
    I just replaced the rotor in mine about 100,000 miles ago... no issues...
    Mendel Leisk and xliderider like this.
  4. xliderider
    xliderider Senior Member
    7,906
    3,136
    Honolulu, HI
    I cleaned the whole EGR circuit at 120K and contemplated changing out the water pump at the time with one of those Amazon Aisen units with the Toyota ground off the housing. It would have been a good time to do it since I drained the original coolant out to do the EGR cleaning.
    I read that those pumps tended to fail early, so I ended up leaving the original pump in the car.
    I have subsequently bought a replacement rotor, so I have to to decide whether to change the rotor only in the original pump, or install the replacement pump (Toyota ground off) with the replacement rotor installed in it. Decisions, decisions.
    Currently, the car is at 135K.
    SM-G781V ?
  5. Mendel Leisk
    38,991
    That may be the way to go. I googled:
    replacement rotor for Aisin WPT-090
    And got lots of results, including this on Amazon.ca, for $37 CDN.
    Any trick to getting the rotor out, maybe some sort of circlip?
    #5 Mendel Leisk, Sep 22, 2024 at 4:13 PM
    xliderider likes this.
  6. ASRDogman
    6,292
    3,354
    Replacing just the rotor is easy. There is a tiny "o" ring holding it in place.
    Check the original one for cracking white plastic, or fan blades.
    I was going to leave the OEM on in place, until the pump slipped out of my hand and
    I broke the empeller...... So I put the new one in....
  7. tamo3
    tamo3 Junior Member
    22
    CA, USA
    I just replaced rotor too. It the only part of the water pump worn out.
    Here is my old 120k miles rotor from Prius 2010.
    Some people will get cracked plastic parts.
  8. MAX2
    MAX2 Member
    347
    81
    Third Rock from the Sun
    A small part that ultimately affects the entire engine.
    If it is damaged, the temperature in the cooling system increases, overheating, breakdown of the engine head gasket, seizure, engine cemetery.
