12v battery suggestions?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by taxce, Sep 25, 2024.
  1. taxce
    taxce Junior Member
    28
    california
    Any suggestions for the best deal on a replacement 12v battery?
    I see costco offering an AGM with a 36 month warranty for $178.
    I've heard AAA will come and install a battery, but I can't find price or warranty info.
  2. Brian1954
    Brian1954 Senior Member
    2,410
    968
    South Central PA, USA
    Walmart has the AGM battery for $180 in my area.
  3. DirkAshburn
    DirkAshburn Member
    158
    65
    Virginia
    2nd on WalMart. Bought several now for our cars.
  4. bisco
    52,398
    check the dealers, they might be competitive
  5. PriusCamper
    PriusCamper Senior Member
    13,078
    5,306
    Pacific Northwest, USA
    taxce likes this.
  6. taxce
    taxce Junior Member
    28
    california
    Wow that's great thanks. The yellow top battery I used to buy has skyrocketed in price to $289. But this one you found is a big savings even over the less expensive batteries available at costco/walmart.
    It will fit properly in 2010 Prius?
  7. Mendel Leisk
    41,923
    How do you deal with this:
  8. PriusCamper
    13,078
    5,306
    You put washers slightly large than size of terminal on the top and bottom of terminal and use a bolt, slightly longer than ones it comes with. As in the washers are like the bread of a club sandwich and the bolt is a tooth pick and the car's battery terminal is the meat in the middle.
