Parasitic battery drain?
Discussion in 'Gen 5 Prius Technical Discussion' started by Paul Gregory, Mar 10, 2024.
  1. Approximate Pseudonym
    106
    52
    Colorado
    2024 Prius Prime
    XSE Premium
    My car doesn’t have a tracker, and isn’t dealer financed. I believe that some issues people have with parasitic drain or battery issues must be caused by trackers or other accessories, but I already ruled those causes out before diagnosing the battery issue. It was one of the first things I had to check.
  2. Rafsdhc6
    Rafsdhc6 Junior Member
    Ontario
    2023 Prius Prime
    XSE
    12v just died in mine also. 14 months old and about 8000 miles. 5 days ago it was on a 200 mile road trip with no recharge. Plugged in overnight 2 days ago and was driven the following day about 25 miles. Today with a remaining charge of 45% died while trying to start.
  3. Approximate Pseudonym
    106
    52
    Colorado
    2024 Prius Prime
    XSE Premium
    Six month update: no issues at 4,810 miles, since March 14 12v warranty replacement.
  4. Rcrowell1971
    Rcrowell1971 New Member
    Nova Scotia
    2024 Prius Prime
    SE
    I just had my dealership check my 2024 Prius Prime as we had drained battery one morning. They said the battery checked out OK. But they found a bulletin for 12V battery depletion when connected to the charger. They calibrated the plug-in charge control ECU as per TSB-TCI-6016 CODE EE2411.
    AndersOne and bisco like this.
  5. Gokhan
    Gokhan Senior Member
    4,825
    1,902
    Paramount CA
    No, once the AC charging is finished, the battery depletes faster if you keep the car plugged in, with the TSB resolution or not. That is because a 12-V subsystem that checks the plug continuously operates when the car is plugged in. Therefore, you should unplug the car as soon as the charging is finished or at the earliest possibility. Perhaps the TSB resolution helped, but it won't stop the 12-V subsystem from being active when the car is plugged in and the AC charging is finished. Note that during AC charging, the 12-V battery receives a float voltage, but once the AC charging is finished, it will start draining.
    Also get a charger like a Noco Genius, as the car will not fully charge a fully drained battery. It has probably lost capacity as well because of the full drain, but if you occasionally manually charge it, it could last for a couple of years.
    #105 Gokhan, Sep 26, 2024 at 2:59 AM
