Weird AC Issue
Discussion in 'Gen 3 Prius Technical Discussion' started by chyis, Sep 23, 2024.
  1. chyis
    chyis New Member
    Vehicle: 2010 Prius
    The AC work off and on, I figure it might be low on freon and when I took the vehicle to the shop, the mechanic said the pressure is correct and does not need to be recharge. I checked the 10a AC fuse under the steering column and its good.
    Anyone ran into this issue before or know where I should check?
  2. MAX2
    MAX2 Senior Member
    1,436
    487
    101
    Third planet from the Sun
    Is your air conditioner malfunctioning and causing errors?
    You need to diagnose your air conditioner system for errors.
  3. Tombukt2
    12,959
    2,325
    I'm sure you're trying to run it in auto mode be my guess what happens if you said it to LO for the temperature push the button for the air conditioning compressor to be on and put the fan on well let's say medium to start everything working now Just curious?
  4. chyis
    chyis New Member
    How do I check for errors?
  5. chyis
    chyis New Member
    Owned this vehicle for approximately 6 years now, never had an issue until now. No matter which temp setting its in (Auto etc) with AC button engaged and fan at low or high setting, it does not affect the AC comp from engaging.
  6. MAX2
    MAX2 Senior Member
    1,436
    487
    101
    With the car turned off, press and hold two buttons on the climate control - air from the cabin (or from the street) + the AUTO button and press the start button to turn on the ignition.
    Error numbers are displayed
  7. chyis
    chyis New Member
    Thank you. I will give that a try tomorrow when I'm back home.
    By chance, if there's stored code(s), will the code be displayed as number on the HUD?
  8. MAX2
    MAX2 Senior Member
    1,436
    487
    101
  9. chyis
    chyis New Member
  10. chyis
    chyis New Member
    The weird thing is, if I engage the AC button, the green light will turn in but just blow cool air. If I turn the vehicle off and back on, the compressor engages and blows cold air.
  11. ChapmanF
    18,179
    Also, in a gen 3, you can use any suitable OBD scan tool (suitable meaning one that can talk to all ECUs in the car). It will show B14xy codes that generally correspond to the same xy codes you can see using the display as described above.
