Easiest way to run a new wire through firewall?
Discussion in 'Gen 3 Prius Technical Discussion' started by Seymour1, Sep 26, 2024.
  1. Seymour1
    Seymour1 Junior Member
    220
    I want to add a new horn but to use independately. I need a wire to go from a new horn button to the engine compartment. Any ideas?
    I once had a Camry that the weak horn operated normally unless I also had my foot on the brake petal. Then, the loud horn blew. I could select loud or soft.
  2. ChapmanF
    16,129
  3. Seymour1
    220
    Thank you. This is exactly what I was looking for.
    At first, I was a little confused by ebay commercials in between posts. The commercials looked highly technical
    but did not make sense.
  4. TNToy
    TNToy Member
    70
    Memphis TN
    This is easy to set up with a relay, for the record., using the factory horn button on the steering wheel. You’d only have to run a wire tied into the stop light switch (12v+ with brakes applied) into the engine bay.
  5. Seymour1
    220
    That is how I did it on my Camry and plan to do on my Prius. But I still need to run a wire through the firewall. I doubt that the existing brake light wire goes in to the engine compartment.
  6. ASRDogman
    ASRDogman Senior Member
    6,348
    3,380
    (n) So everytime they press the brake pedal the horn sounds? Nifty! :ROFLMAO::whistle:
  7. Seymour1
    220
    No. Every time the horn blows, the brakes are applied.
    I connected one side of the new relay coil to the brake circuit (normally zero volts). I connected the other side to the anode of a 1 amp doide anode. The cathode connects to the horn button circuit. x
    ASRDogman likes this.
  8. ChapmanF
    16,129
    ¿ o_O ?
  9. Seymour1
    220
    Chap- I was answering a prior post. I am trying to learn how to include the prior post with my answer.
  10. xliderider
    xliderider Senior Member
    7,913
    3,140
    Honolulu, HI
    Click on the "quote" button on the post you want to quote. Then add your text after the quoted text.
    SM-G781V ?
  11. ChapmanF
    16,129
    Me, I'm trying to figure out how a person would arrange for the brakes to be applied when the horn blows.
  12. Seymour1
    220
  13. Seymour1
    220
    I have to add a relay and a diode for it to work correctly.
  14. ChapmanF
    16,129
    Are you thinking you'll do something electrical that will cause the brakes to be applied?
  15. TNToy
    TNToy Member
    70
    Memphis TN
    You need to learn more about how versatile relays can be.
  16. ASRDogman
    6,348
    3,380
    You need to learn and recognize a joke...
  17. ChapmanF
    16,129
    pretty sure i've just recognized two
  18. Seymour1
    220
    No. I was posting a (funny) reply to a post that asked if the horn will blow when the brakes are applied. I thought that the person was joking. I apologize.
    So, here is what I think will work. see attached drawing. The diode leads must be secured so that they do not flex due to vibration. I think the hardest part is running a wire through the rubber grommet in the firewall. It is hard to reach. IMG_2895.JPG
  19. ChapmanF
    16,129
    Ah, ok, that makes sense.
  20. Seymour1
    220
    It did strike me as funny if the horn would blow when touching the brake petal.
