Touch-Up Paint for 2024 LE Wheel Cover & Rim?
Discussion in 'Gen 5 Prius Main Forum' started by DBinSJ, Sep 27, 2024.
  1. DBinSJ
    DBinSJ New Member
    San Jose, California
    2024 Prius
    Any suggestions as to where I might be able to find touch-up paint for a 2024 LE wheel cover and rim would be most appreciated.
    (Went to a Toyota dealership parts department, where they looked at me as if I was crazy, saying no such thing exists, and wanted to sell me a new wheel cover, for $170+.)
  2. Mendel Leisk
    41,119
    I had a similar quandry with a Tesla 3 rim, a deep-gray, almost but not quite black. Forum discussion suggested a Ford colour that was “close”. I think the solution for the LE wheel covers will be similar: no official paint code disclosed, but owners sort something out.
    I know for house paint you can bring in a sample to a paint store; they can scan and match it. I wonder could an automotive body shop do similar, make you up a small jar, say for $50.
    DBinSJ likes this.
  3. reservoirblue
    reservoirblue Member
    Woodacre, CA
    2024 Prius Prime
    SE
    I don't know about the wheel covers (I removed mine). For the rims themselces I have used this:(bought at Amazon for $6.-). It's not black-metallic but gloss black. Appears to have worked fine.
    Rust-Oleum Paint 213174 .6-Ounce Specialty Brush Bottle Appliance Touch Up, Black, 0.6 Ounce
    DBinSJ likes this.
  4. DBinSJ
    DBinSJ New Member
    2024 Prius
    Thank you so much for your kind reply! We'll give that a try.
  5. DBinSJ
    DBinSJ New Member
    2024 Prius
    Thanks very much! We'll look into it.
  6. Mendel Leisk
    41,119
    The cover looks to be a medium-dark grey though.
    DBinSJ likes this.
  7. vvillovv
    vvillovv Senior Member
    4,320
    1,508
    NY
    If you can't find the paint you want from searching the web and the dealer doesn't carry of offer any, you'll have to go after market to get your paint color(s).
    Here's a few links to get you started. see also techi stuff below
    Touch up Paint - Clear Coat
    Touch Up Paint
    Code:
     https://www.amazon.com/Genuine-Toyota-00258-00040-21-White-Touch-Up/dp/B0060BELNA
    after market links
    Exact-Match Automotive Paint for Less: Buy Touch-Up Auto Paint Online for High Quality at a Low Price | AutomotiveTouchup
    Automotive Touch Up Paint from PaintScratch - Order Pro Grade Paint - PaintScratch.com
    rattle can - spray paint only (probably not what you are looking for)
    OEM Automotive Paint Match | Car and Truck Touch-Up Paint
    Tech Stuff:
    Toyota uses waterborne paint on body panels.
    It shouldn't matter that most touchup paint available is typically lacquer based - most people wouldn't know the difference anyway.
    Trim and wheel covers are probably painted using lacquer based paint anyways. You probably wouldn't notice a difference unless the things you paint are not prepped correctly for the paint you are using and something bad happens.
    The paint code for your cars OEM paint is a 3 digit (numbers and letters) on your driver side door jams Label
    ( not sure if you are asking for paint colors that match the car body color or some other colour(s) since I don't have a Gen 5 )
    #7 vvillovv, Sep 28, 2024
    DBinSJ likes this.
  8. Mendel Leisk
    41,119
    FWIW, for the aforementioned Tesla 3 rims, the touch-up I used was Ford CX Dark Shadow Grey CAFM 0360. Here's a Google image search result for that colour:
    ^ And the 5th gen Prius LE wheel cover, for comparison. If your wheel cover curb rash is just on the edge, that Ford color might be close enough. For touch-up of the rim itself, is it gloss-black? Not sure.
    I think the Ford colour is a bit warmer. But close. Depends on the lighting too.
    Or Guardian Grey, one of the 5th Gen Prius body colours:
    ^ With our 3rd gen, which was Classic Silver Metallic, our 17" rims were a similar dilemna, and surprise, surprise, the riims were exactly the same colour:
    another thought: there apparently are colour match apps for smartphones; duplicolor may make one.
    #8 Mendel Leisk, Sep 28, 2024
    vvillovv likes this.
  9. DBinSJ
    DBinSJ New Member
    2024 Prius
    "For touch-up of the rim itself, is it gloss-black?" The rims look to be the same color as the wheel covers.
  10. DBinSJ
    DBinSJ New Member
    2024 Prius
    THANK YOU so very much for all of this excellent information! I have copied it into a Word file on my system, to carefully go through all the options. Most appreciated!
  11. Mendel Leisk
    41,119
    I tried Dupli-Color's app. It loaded a splash screen with their name, in pretty colours, and that's it... Could be my phone (iphone2).
    Just for giggles, check with a few body shops. They match color all the time. Maybe if you brought in a wheel cover they could make you a bottle of touch-up, maybe even with an applicator brush on the lid. Trust me, you'll need it; there are curbs everywhere, just waitin'...
  12. reservoirblue
    Woodacre, CA
    2024 Prius Prime
    SE
    On my car the rims are glossy metallc black, the covers more matte grey-ish.
  13. DBinSJ
    DBinSJ New Member
    2024 Prius
    Here's a close up of what the wheel cover looks like (not the scratched one). We're now searching for a good color match.
  14. Humble Bear
    Humble Bear Member
    130
    49
    Arcadia, CA
    2024 Prius
    (Went to a Toyota dealership parts department, where they looked at me as if I was crazy, saying no such thing exists, and wanted to sell me a new wheel cover, for $170+.)[/QUOTE]
    1 wheel cover for $170??:sick: or A set of 4?
  15. DBinSJ
    DBinSJ New Member
    2024 Prius
    "1 wheel cover for $170??:sick: or A set of 4?"
    That was actually the price quoted for a single wheel cover at my closest Toyota dealership (I asked for clarification, just to be sure). I'm pleased to report, however, that in the meantime, I found a place locally that provides customized color paints in small amounts for touch-up work like the kind needed in my case, for about $60. It can be stored for a long time under the right conditions, for touch-up work on the wheel covers in the future. (You find the right color by holding up swatches to the area in question, until you find what seems like a relatively exact match.)
  16. Templeton
    Templeton Member
    255
    72
    usa
    2024 Prius Prime
    SE
    I am curious, what do these wheels look like with the covers off? Can you post a photo?
  17. Humble Bear
    Humble Bear Member
    130
    49
    Arcadia, CA
    2024 Prius
    They don't come with the center caps, but you can get them from the dealer.
    Templeton likes this.
