Can Default View on MM Screen Be Customized?
Discussion in 'Gen 5 Prius Audio, Electronics and Infotainment' started by 23PriLE, Sep 6, 2024.
  1. 23PriLE
    23PriLE Member
    95
    67
    North Central Florida
    2023 Prius
    When driving I like to have the Fuel Economy History displayed on the Multimedia Screen. That's the one with a bar graph that shows the overall MPG for that day and several previous days.
    I often make several stops when running errands and every time I restart the car I have to tap the screen 3 times to get to the correct display. Is there any way to set this as a default so that it displays when I restart the car without having to tap the screen repeatedly?
  2. mk4
    mk4 New Member
    interstellar space
    Is there a chart displaying days (on the x-axis)? The one I recall has 5 min intervals on the x-axis.
  3. 23PriLE
    23PriLE Member
    95
    67
    2023 Prius
    Yes, the first screen that comes up, which is labelled Current, shows the 5 min intervals. At the top there is also an option for History. You have to tap Reset (not Clear) to start a new bar graph for each new day.
    It will show you the overall mpg for the day. I have my MID set up to display the mpg for each "trip". That display comes up every time I turn off the car and is reset each time I start the car. If I want to monitor the overall mpg for the day while I'm driving around I have to tap the screen 3 times every time I restart the car.
    Lately I've just been bringing up the graph the first time I start the car so I can Reset it for that day, then I just turn the Display off and don't check again until I Reset the graph for a new day, or sometimes I check it when I've finished my driving for the day.
  4. darkstar3274
    darkstar3274 Junior Member
    46
    2022 Prius Prime
    What a waste of space on that multimedia display be it 8 or 12.3 inches. All the Toyota engineers had to do was to put up a view like the prior gen 4 with a tabular format showing trip, day mpg with miles driven switchable to week and month...instead we have a junk bar graph with real time useless info lol..."multimedia display" euphemism for a monitor to display what your phone already shows-this is simply the worst part of the car imo
  5. vvillovv
    vvillovv Senior Member
    4,321
    1,509
    NY
    Worse than the new subscription models so many computer companies are currently implementing, or not quite that annoying?
