10K oil changes are BAD! ??
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by NewHybridOwner, Aug 3, 2022.
  1. Bill Norton
    Bill Norton Senior Member
    1,892
    621
    MONW, Ks.
    Off Topic....
    Thanks for the link.
    I have now joined the EGR Delete Club this morning!
    I'm at 153k miles. I know I should clean the EGR system someday....
    And the way I drive I never have two tank fulls the same MPG. It might be hard for me to quantify any difference.
    burebista likes this.
  2. MikeDee
    MikeDee Senior Member
    1,560
    593
    San Francisco Bay Area
    Doesn't that discredit the theory that a clogged EGR system will fail a headgasket?
  3. Mendel Leisk
    39,016
    I could come up with some reasons, but I think your mind’s made up.
  4. ASRDogman
    ASRDogman Senior Member
    6,317
    3,366
    No one has 100% found the exact reason. I personally believe it is a combination of things.
    And at times, certain things. And it seems those who do mostly city driving have issues
    sooner and more often than those who do mostly highway driving. And also HOW it's driven.
  5. Bill Norton
    1,892
    621
    MONW, Ks.
    It's just the opposite.
    It's implying that without an EGR system to get clogged in the first place, Prii in Brazil do not routinely have a head gasket go bad.
    Of course this is Hearsay without actual data to back that statement up.
    Only the Brazilian Toyota mothership knows what the Toyota dealerships report in the way of repairing head gasket failures.
    Of course, just like here, Toyota doesn't know the extent of HG failures because a lot of the repairs take place in independent repair shops.
  6. MikeDee
    1,560
    593
    I found it interesting that the water pump impeller on your high mileage car was in good shape whereas other folks are saying theirs were badly deteriorated at much lesser mileage. That tells me they haven't been changing the coolant at the prescribed intervals or used inferior coolant. I think poor maintenance practices contribute to the headgasket life. Corrosive coolant is going to eat the headgasket and water pump and raise operating temperatures and cause overheating. Of course driving practices contribute as well.
  7. bisco
    49,844
    of course, the maintenance schedule has quite a long interval for coolant changes, and no rec for testing.
    dealers aren't helping ether, and toyota europe claims it is because of faulty waterpump speed software.
    Bill Norton likes this.
  8. ASRDogman
    6,317
    3,366
    90% of my driving is highway. So they engine temperature is more steady.
    With city driving, it changes. So that's likely part of the reason it fails, it's plastic...
  9. Bill Norton
    1,892
    621
    MONW, Ks.
    Seems like a strange reason for an electric water pump with a plastic impeller to fail.
    Its duty cycle is always changing RPM. I'm hoping the latest and greatest SW update addresses the duty cycle to help with the head gasket at high speed/power duties.
    Do you recommend changing the entire pump assembly at X miles, preventatively? Can the impeller be changed separately?
  10. Mendel Leisk
    39,016
    Apparently. Of late there’s been a lot of impeller-only offerings. There’s a thread here with some discussion.
  11. Mendel Leisk
    39,016
    Google "Aisin WPT-190 impeller". Apparently not hard to replace either; a circlip of some sort needs to be removed and out it comes?
