It's dead.
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by AlanS, Oct 2, 2024.
  1. AlanS
    AlanS New Member
    Dunedin
    2014 Prius v wagon
    Hi. Have on loan a 2014 Prius wagon. After a battery recharge the prius will not go into gear (R or D) and a dashboard orange warning light flashes. Has a "P" in a box and an arrow pointing at the "P"?
    Photo attached. Any ideas?
  2. AlanS
    AlanS New Member
    Dunedin
    2014 Prius v wagon
    Better picture.
  3. Air_Boss
    Air_Boss Senior Member
    4,197
    1,183
    New Yawk
    Is it possible that during the (assuming 12V auxiliary) battery recharge, polarity was even briefly reversed?
    bisco and Brian1954 like this.
  4. bisco
    51,901
    would be worth having the battery tested before going down the lengthy and complicated diagnosis path.
    btw, what does 'on loan' mean?
    Air_Boss likes this.
  5. Brian1954
    Brian1954 Senior Member
    2,194
    862
    South Central PA, USA
    You need to use an OBD2 scan tool to read the trouble codes.
    Rmay635703 likes this.
