Red triangle but good mpg
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Dahvid, Aug 30, 2024.
  1. pasadena_commut
    pasadena_commut Senior Member
    1,630
    489
    Southern California
    Contact Autel support? Either they tell you how to get those codes, they tell you that you cannot get those codes, or they don't answer. Two out of three you end up knowing more than you do now.
  2. ChapmanF
    16,061
    We know the INF codes are in the freeze frame. What we don't know is why that tool showed "no data" when you asked for the freeze frame.
    Brian1954 likes this.
  3. Brian1954
    Brian1954 Active Member
    996
    357
    South Central PA, USA
    When you did the "full scan", were many systems scanned like; Engine and ECT, Hybrid Control, Transmission Control, ABS/VSC/TRC, SRS Air Bag, Body, Air Conditioner, Hybrid Battery, Cruise Control, EMPS, Immobilizer, Gateway, Smart Key, and Power Source Control?
    When you clicked on the freeze frame button, were you sitting in the car with the car "on" with the Autel AP2500 plugged into the OBD2 port?
  4. Dahvid
    Dahvid Junior Member
    30
    Usa
    Yes it was on a scanning screen and it went through all those systems you listed where it came up with the p0aa6 code
    And yes I was sitting in the car with the car in ready mode and while running. I have to clear the code to start it but it comes back on shortly after most times.
    Yes it scanned all those systems for full scan
    I tried to record my screen but it says it's an invalid extension. It's an mp4 video file
    I'm in the car with the car in ready mode. I've even tried it with the car on after the car has started (after clearing code) and still no data/ blank screen
    I leave the dongle plugged in (ap2500)
    Autel AP2500 OBD2 Scanner...
    I'll try downloading different builds of the app and seeing if that helps.
  5. Brian1954
    996
    357
    The car only needs to have the ignition on (2 pushes of the start button without touching the brake pedal) for the scan tool to work. The car does not need to be in "ready." Do NOT clear the trouble codes. Clearing the codes also deletes the freeze frame data.
    First, make sure the 12v battery is fully charged. Then put the car in ignition on. Then, do a full scan. Then check the trouble codes, and if you have code P0AA6 (current), look for the freeze frame data.
  6. ChapmanF
    16,061
    ... and if that freeze frame only has an INF code 526 in it, then power the car off, without clearing anything, and try to go READY again, without clearing anything, and then (whether it went READY or just stayed at IG-ON with the triangle showing), scan for codes and get the freeze frame data again, and now there should be two INF codes.
  7. dolj
    dolj Senior Member
    7,805
    3,946
    Wellington, New Zealand
    In addition, reiterating ChapmanF's post (#46) above, if the only INF code is 526, do not clear codes, turn the car off, and then put the car in IG-ON again. Rescan and there should be a second INF code in the 611-614 range.
  8. ChapmanF
    16,061
    Depending on where the fault is, it may be necessary to try to go READY before scanning again, not just IG-ON. It matters not whether the car successfully goes READY or just lights the triangle and stays IG-ON. On no account think "I have to clear the code so it'll go READY"; that'll just defeat the purpose.
  9. Dahvid
    30
    Usa
    Understood, I just cannot get anything to populate under freeze frame. In the maxi app, only engine data shows under "live data" I've attached a long screenshot of that
    As I understand it the inf codes I'm looking for will but under "freeze frame" which nothing populates for me. 2nd screenshot
  10. ChapmanF
    16,061
    Correct. Autel support is probably the right channel for why you get nothing under freeze frame.
  11. dolj
    dolj Senior Member
    7,805
    3,946
    Are you downsizing your images or selecting some kind 'small' option when uploading your image file?
    I ask because the images are so small (even if I max zoom in on them) they are not of any use.
    Could I ask that you size your images so the width is around 1220 to 1440 px?
  12. ChapmanF
    16,061
    I don't know for sure, but I have a bad feeling that Dahvid probably uploaded that image and XenForo 'helpfully' scaled it down to a maximum height.
  13. dolj
    dolj Senior Member
    7,805
    3,946
    I'm not sure about that, the other image is tiny too and that is a more normal aspect ratio for a portrait screenshot.
  14. Dahvid
    30
    Usa
    Just as update I am still waiting for a response from Autel. I just sent another follow up email today but I originally emailed them on the 30th
    This is who I emailed [email protected]
    I have a mobile mechanic who's willing to go in there to see if there's any corrosion or water ingress for $100/hr 2 hrs max to do that. This is also the same mobile mechanic who's tablet style launch x431 could also not locate any inf codes
    Thoughts? I was trying to avoid paying anyone until I got the inf codes bc I wanted to figure out what the problem is first and the appropriate course of action.
    I'm waiting to do other repairs as well until I can get this figured out.
    Thoughts?
  15. rjparker
    8,259
    4,901
    If it’s your hv battery that needs replacing, there is no reliable option other than new oem modules. Used, reconditioned, matched or aftermarket will have you doing it over and over again.
    The hacked Techstream is more robust with plenty of people here who know how to use it. Lower cost as well if you are ok with hacked and will do everything except ecu updates and pro locksmith functions.
    As stated before, the high voltage leakage could be at your AC compressor, the inverter or any orange cable. Not exclusively at the hv battery but it is likely worn out as well.
    I would be careful about calling out Boomers who invented most of this technology and are largely who you are seeking help from. To say nothing about having the time to help. Most of them can easily setup their scanners and get codes with detail. Experience counts.
  16. Dahvid
    30
    Usa
    Not calling anyone out. Just saying I'm somewhat technically inclined hopefully enough to explore running techstream.
    Any reliable sources to get it?
