Dashboard lights not working on 2008 Prius?
Discussion in 'Gen 2 Prius Technical Discussion' started by Todd Greeneway, Oct 2, 2024.
  1. Todd Greeneway
    Todd Greeneway New Member
    Appleton
    I’m new to this forum and wondering about getting the dash lights to work. I used Tom be able to push power button once, hold in climate button, and flick lights and dash board would come on but this method doesn’t seem to work any longer? Recent changes: new auxiliary battery installed, new brakes.
    Does anyone have other ideas? Trying to avoid paying $1000 for new combination meter. thanks much!
    Todd
  2. Tombukt2
    12,957
    2,325
    New combination meters 175 from Texas hybrids in about 1.2 hours of most idiots time to install it in about 12 screws pull out the vents blah blah blah millions of videos online and that's that all the flickering and smart with the battery terminal negative and all that has been used up and now you got no choice but to fix it everyone else has been playing games with the car until you got it now you're trying to play the same games and they don't work anymore very common actually You're at the end of life of playing with the battery terminals and playing all the little games that everybody tells you to play online That's ended pretty much sorry maybe it's time for an easier car for one to deal with that is a possibility Prius can be very complicated for well the easier going crowd anyway
  3. dolj
    dolj Senior Member
    8,442
    4,289
    Wellington, New Zealand
    Hi Todd, welcome to PriusChat.
    There is no need to spend $1,000 for a new CM. If you are a little bit handy, you can do it yourself using the service below.
    Texas Hybrid Batteries provides a repair service or can send you a remanufactured unit in exchange for your old broken CM. It costs $150 plus a $75 core charge. You get the $75 back when they receive your old board. The service includes programming your odometer to the current mileage and a lifetime warranty.
    The details are in the link above.
  4. Todd Greeneway
    Appleton
    I have a 2008 Toyota Prius with dash light out. I used to do the trick with pushing button and flick the lights. However, when I replaced auxiliary battery, that process doesn’t work any longer. Any suggestions?
    Thanks Todd
  5. Frontporch
    Frontporch Active Member
    525
    117
    Nj
    Todd, you would get more visibility in the Gen 2 forum for your question. I remember there was a more lengthy dance that someone on youtube said was 100% successful. Might want to search for that.
    I know the pain you have when the dash goes dark. Its not the worst fix if you are handy and have some time.
  6. ChapmanF
    18,156
    Yes ... (a) this should be moved to the gen 2 forum, and (b) there are plenty of threads already there about this known problem.
    The gen 2 combination meter starts to do that because of a small capacitor on the meter circuit board. Existing threads describe what capacitor to replace. The part costs around a dollar, solder skills are needed, and taking off the dash top to reach the meter board is a tedious job.
    There is a service in Texas that will send a working meter (preprogrammed with your odometer mileage) and you send your old one to them, for a cost around $150 if I remember right.
    There is no "dance" that does anything but prolong the agony. You can make up lots of dances that will work, less and less often, until they just don't. What's failing is a capacitor on the meter board and what fixes the problem is a good capacitor there.
  7. Tideland Prius
    16,555
    Threads merged
