Red triangle but good mpg
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Dahvid, Aug 30, 2024.
  1. rjparker
    8,268
    4,903
  2. Dahvid
    Dahvid Junior Member
    32
    Usa
    Given the amount of corrosion and lack of any visual evidence of leaking, could it be a short in the wires that connect to the relay? I'm just thinking out loud and doing some cursory searches on YouTube to find out more.
    Thanks
  3. mr_guy_mann
    mr_guy_mann Senior Member
    3,606
    1,662
    NJ-USA
    After you did a "system scan" with the autel, did you select "HV battery" system and go into that part of the menu?
    If you were in the ECM - engine section, that would explain the data you retrieved and the lack of freezeframe.
