GEN 1 prius P3106 powertrain code and vehicle stalls
Discussion in 'Generation 1 Prius Discussion' started by blake9809, Jul 8, 2024.
  1. blake9809
    blake9809 Junior Member
    42
    Minneapolis, Minnesota
    2002 Prius
    SE
    thank you for the explanation and all makes sense. Now i do understand why it was acting that way. Currently have the hybrid battery out of the vehicle and apart. I will replace the low cell and re-install the battery this week. I plan to charge the battery with a MAXX volts charger and hopefully that will balance all the cells.
  2. blake9809
    42
    2002 Prius
    SE
    still not sure what the P1437 code is caused from but i guess just drive it.
  3. ronlewis
    ronlewis Active Member
    921
    185
    texas
    2001 Prius
  4. ChapmanF
    16,075
    That code is about one specific vacuum line, and it is the one that works the HCAC actuator down on the exhaust pipe. The actuator moves a flap inside the exhaust pipe and sometimes from the heat and accelerated rusting it gets stuck. This thread may be of interest.
  5. ronlewis
    921
    185
    texas
    2001 Prius
    Chap forgot the link, but there are many discussions of this DTC here. SYK, driving the car in the snow of MN will almost always lead to this issue. The flap and actuator rod will rust over. Another thing you should check is the fuel filler neck. They rust from snow as well and will kill the fuel pump inside the gas tank so you have to replace the entire tank. Just reach up in the rear wheel well and feel over the top of the filler tube right at the fender. The tire will throw the snow up there and it gets packed solid. Then, if it stays cold the snow rusts a hole through the tube. Later, when spring comes around, the tires will throw water up there that gets in your tank. The tube itself is easy to replace. I got some spares if you need one.
  6. ChapmanF
    16,075
    a couple words in post #44 are bluer than the rest
