2024 toyota prius xle door will not lock by holding handle
Discussion in 'Gen 5 Prius Main Forum' started by JeanLuke, Oct 6, 2024.
  1. JeanLuke
    JeanLuke Junior Member
    Austin TX
    Recently got a 2024 XLE, and am loving it overall, but I'm unable to get the door to lock by holding the outer handle and touching the grooved spot on it, as is the case with my Gen 3 Prius. Any help will be appreciated. Key fob works fine, but if I try to lock by just holding the handle, it emits a tone like if you left the fob inside the car and try to lock it.
  2. RandyPete
    RandyPete Active Member
    403
    167
    Santa Margarita, CA, USA
    2024 Prius Prime
    XSE
    Where is the fob when you try this ?
  3. Hammersmith
    Hammersmith Senior Member
    2,315
    2,359
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Things to check:
    - Are you putting your hand inside the door handle when you try? You don't have to do that to lock, only unlock. When locking, only touch the front part of the door handle.
    - Is the car off? It won't lock from the outside if it's in Ready or Acc mode.
    - Is there a keyfob in your car? If you got a second keyfob, make sure it isn't in there when you try to lock your doors.
    - Is your phone in the car? If you set up your phone through Digital Connect, it acts like a keyfob. Also, if you wear your phone in a front pocket, you might need to go into the app settings and turn the sensitivity to low. Low is good for a front pocket, medium is good for a normal purse, high is good for an oversize purse full of stuff or a backpack. The size/thickness of a phone case can also affect this.
    - Did you open a rear door around the time you got in? This gen of Toyotas have a safety feature to remind you there might be something(like a child) in the back seat. It's triggered by the rear door being opened and closed within a certain time window of the front doors being unlocked and the car started(I forget the details because it's a disableable feature and I turned it off within a couple weeks of ownership).
    Start there and let us know if none of this works.
  4. Gwyd
    Gwyd Member
    113
    78
    NE Florida
    2023 Prius
    There's a groove in the front part of the handle, towards the engine. About where your thumb would fall if you put your right hand on the handle (driver side). You just need to touch this, not hold it - I run the back of my hand over it in a swiping motion when walking away, so it doesn't need to be a fingerprint touch.
    As Hammer said grabbing the inside is what unlocks - so if you're putting your hand fully into the handle and trying to lock it, you're confusing the car by sending a lock and unlock signal at the same time.
    CooCooCaChoo likes this.
  5. JeanLuke
    Austin TX
    In my pants pocket
  6. JeanLuke
    Austin TX
    Answer is no to all questions. I also disabled the rear seat alert, and still just emits a tone for several seconds.
  7. JeanLuke
    Austin TX
    Just touching the groove. Not holding handle.
  8. Sansha
    Sansha New Member
    Washington DC
    2024 Prius
    Any luck on this issue? I just bought a 2024 xle this weekend and I am having this same issue. The long error tone when I try to lock at the door handle. Key and phone in separate pockets.
    For will only lock with fob or app.
    The dash tells me that a new digital key was registered and to contact my dealer every time I start it.
