Is there an oil leak that cannot be fixed?
Discussion in 'Prius v Main Forum' started by PriusPaddler, Oct 7, 2024 at 3:27 PM.
  1. PriusPaddler
    PriusPaddler Member
    131
    25
    Twin Cities, MN
    I am trying to buy a used prius v.
    The one I really like is a 2012 with 135,000 miles on it. Appears to have been well maintained and body is in fabulous condition.
    A private inspection today revealed oil leaks. Not just seeping but actually leaks. They recommend degreasing and dyeing the oil to find out where it's coming from. They do not want to estimate repair until they know.
    My 2009 regular Prius didn't have oil issues until after 300k.
    Is this a risk worth taking? Dealer won't budge on price but already $1700 less than next best local deal with 30k less miles.
    All other items checked out fine (except wiper blades).
    Assuming I have $1700 to throw at it, any kind of leak not fixable??
    Thanks, gotta decide soon.
    49,858
    i would pass. the gen 3 engine has reached it's useful life. it is nothing like gen 2, unfortunately.
    if you really want a v, look for a 2015, with less than 100k on it. you ight be able to save it before the head gasket blows.
    gen 3 has several issues that gen 2 did not have, making them ticking time bombs.
  3. BiomedO1
    1,693
    870
    SacTown, Ca
    If a dealership is trying to sell a car with that kind of half-a** multi-point inspection - I'd run away FAST!!!
    I read a thread, awhile ago where someone tightened an oil sender sensor so much that they cracked the engine block thread-in. Obviously you can patch that, but how many heat cycles will that last. Real fix is new or used engine block.
    The reason your 2009 didn't have issues is because it was properly maintained. Do you have the full service history of that car??? and it's a Gen3.
    Just Saying....
  4. PriusPaddler
    PriusPaddler Member
    131
    25
    Twin Cities, MN
    So bummed to hear.
    The alternative at the moment is 2014 with 165k but "only" seeps, no leaks to worry about (per mechanic just watch it). Is that worth it?
    Is 2015 significantly better? Haven't seen those in my budget...
  5. bisco
    49,858
    actually, late 14's got a piston and ring upgrade which continued after that. if you get the vin, someone here has the cutoff point. we've seen a ton of blown head gaskets here, but have no way of knowing what percentage of gen 3's have had it happen.
    there are many possible causes, but nothing definitive.
    egr clogging, incorrect cooling pump software, too infrequent coolant changes and acidity checks, 10k oil changes instead of 5k and more have all been blamed, but no one knows for sure.
    watch
    657835921
  6. bisco
    49,858
    and dealers have been accused of putting in head gasket sealer, which only covers up the problem long enough to get through any warranty.
    the problem is, these cars are in such demand, they can get away with it.
  7. PriusPaddler
    PriusPaddler Member
    131
    25
    Twin Cities, MN
    The 2014 Vin is
    JTDZN3EU7E3319438
  8. PriusPaddler
    PriusPaddler Member
    131
    25
    Twin Cities, MN
    Per the 2014's carfax it was shipped to dealer in December 2013, so my guess is no piston/ring upgrade.
    Probably I will keep my old '09 running then until I can afford 2015 or newer.
    I had never looked at the v until last week, but I have definitely fallen in love with the extra space. I haul three dogs around routinely...
  9. rjparker
    8,286
    4,910
    Built before new rings and pistons.
    Timing chain covers are the common leak point. Around $1200-$1500 to fix. On rare occasions it’s the oil pressure switch, maybe $250 installed or the insertion point, much is more expensive but even rarer. Usually the timing chain cover and it will make a mess all over the engine.
    As noted above, 2010-15 hatchbacks and 2012-17 v’s are problem childs that could cost you $10k with blown head gaskets, engines, brake by wire systems and hybrid batteries. Plus a covered inverter could strand you without warning.
    The v wagons have lower crash test results until a 2015 refresh. Buy conventional Camry, Corolla or Civic if you are on a budget and can’t swing a 2018 or newer Toyota hybrid.
  10. PriusPaddler
    PriusPaddler Member
    131
    25
    Twin Cities, MN
    339374
    Looks like first Vin from plant 3 with new design. :(
  11. PriusPaddler
    PriusPaddler Member
    131
    25
    Twin Cities, MN
    Thanks I'll keep reading and learning I guess.
    On the 2012, I used Dr. PRIUS to check expected battery life and the hybrid was over 85%.
    I was so hopeful and ready to drive it home.
    Should have spent more time here first.
  12. Leadfoot J. McCoalroller
    7,332
    6,842
    Pennsylvania
    2018 Prius c
    Lots of people fall in love with v's.
    There was a lot to like about them.
    So much so that almost all of them have been used up, or are already in the hands of their 'final' owners.
    The ones that are for sale now (2024) are not great choices, apart from maybe the 2017s.
    Time to move on and look at something else.
  13. bisco
    49,858
  14. PriusPaddler
    PriusPaddler Member
    131
    25
    Twin Cities, MN
    Like them, but a) my sister had headlight issues, and b) by the time they started getting decent mpg that prices me out for now.
    Probably a rav4 is in my future some day. I loved my sister's but she couldn't stand the headlights and went back to a subaru.
    I need a hatchback for hauling stuff (have hauled a full size fridge in my '09 Prius). Was excited to see Corolla make a hatch but I think my gen 2 has more space than those.
    Hatch + around 40mpg + leather seats + cabin at least as big as my '09 were my top criteria. Had hoped to stay under/around $10k. May have to reconsider that or delay til budget is higher.
    But my '09 oil leaks need to be addressed if I'm driving it through MN winter.
    Maybe I'll see if civics with hatches are an option.
    Thank you!
  15. douglasjre
    douglasjre Senior Member
    1,945
    669
    Null, NL
    They have another person, just called, who wants it, and said they're on their way
