Dealer put bearing in backwards, maybe. Should I check first?
Discussion in 'Gen 2 Prius Main Forum' started by Minty, Oct 6, 2024.
  1. Minty
    Minty New Member
    New York
    2018 Prius Prime
    2007 Prius, my daughter's car. Dealer just replaced the front left wheel bearing. After driving the car back and forth to work (local roads only) for the week, as she drove to visit us the ABS, VSC and " ! " lights came on after some highway miles.
    Took it to AutoZone where the OBD2 reader said it was a problem with, yes, the left front ABS sensing system, where the bearing had just been replaced. The guy at the counter immediately said the dealer probably put the bearing in backwards so the magnetic strip was on the wrong side. Called our own local mechanic (Saturday morning so they couldn't see car then) who advised to take it back to the dealer, he didn't seem to think my taking the car to him so he could check the bearing was a good idea, I understand that his taking enough stuff off just to check the bearing might be a lot of labor which I couldn't recooup, so I guess he figures that the best case scenario is that the dealer checks, finds it's backwards, replaces it no charge. (I realize that alternatively ABS sensor or harness could be damaged, but if so it almost certainly was damaged during this repair.)
    Which leads to: is the 2007 Prius bearing indeed the kind that has that metal strip on one side, so it even can be put in backwards?
    If it is, and assuming the bearing was put on backwards, my natural pessimism tells me that a dealer would have a strong incentive both not to admit it (for fear of a review that said they put it on backwards) and also not to absorb the cost of putting a new one in. It is very hard for me to picture a dealer saying yup, it was backwards we fixed it, no extra charge. An unscrupulous one could do this, and I don't think it's too far fetched: pull everything off and, if they see the bearing was in backwards, replace it without telling us, and then replace the ABS sensor saying that was the problem. They could then tell us the bearing was installed correctly but the problem was the sensor which they replaced, then they could charge us labor for checking a bearing that (they say) turned out to be fine, admit no mistake, and also charge us for installing an ABS sensor (that perhaps we didn't need). Problem fixed, no admission of fault, and lots of extra charge. They would know the light wouldn't come on again because the real problem, the bearing, is fixed. So in the end we'd have paid essentially about twice what a correct bearing installment should cost. Might sound far fetched, but if you think about it a while not really, given the economic pressures, etc. We'd have no way of knowing whether or not they did all this, the only way to tell would be to watch the whole process of checking it and I assume no dealer would let you do that.
    Ideally it would be great to independently verify whether or not the bearing was in backwards before taking it to the dealer. But I assume that itself would be a big labor charge at our local place that we couldn't recoup. Despite the time and effort, I'm wondering if it would be worth it for me to check it myself - if I did find it was in backwards we'd have a rock solid case for the dealer replacing the bearing free of charge. If it wasn't in backwards, so much the better, we'd save the risk of the dealer charging us for more labor to check it, and it's probably the ABS sensor.
    Any advice as to how to deal with this situation would be welcome, in order for us not to be totally at the mercy of the dealer.
    Additional questions:
    1) Assuming the bearing is that kind with the metal disk on one side, how much stuff would I have to remove before I could access the ring in such a way as to see if it magnetically attracts a screwdriver or whatever? Could I do that short of removing the hub? Would I have to remove the ball joint and axle? Are there seals or a snap-ring that we'd have to take out to access the magnetic strip?
    2) I watched this pretty long but thorough video on replacing the bearing on a 2007 Prius:
    In the video it looked to me that on a 2007 Prius the hub might not be pressed into the knuckle like on many cars, but is just held on by 4 bolts? Could that be true? If so, it seems like if I had to take the hub off to examine the bearing it would be a lot easier than if it were pressed. (But also I might have to take the whole knuckle off like he does in the video to access the bolts? Not sure. Still a lot easier than pulling a pressed hub?)
    I have never done this before, but I am retired and have time and would be willing to risk the usual frustration and frozen bolts and it's taking eight times more time than I thought and hopefully not breaking something else in the process, (We could loan our daughter one of our cars.) if it's reasonable to check the bearing myself. Plus it seems to me since the bearing was just replaced none of the connectors, ball joint, etc., should be frozen, they should come off pretty cooperatively. If it's not in backwards, but then I know for sure, and learned stuff. I could even try to replace the bearing if it is in backwards (I'd try to double check that with a mechanic if I took the whole knuckle off or hub off), document that it was backwards with pictures, and then ask for a refund - except that it seems to me a refund would be far less likely than a free correct installment if I could document it was in backwards. A lot of extra work, but with some certainty and less of a feeling of helplessness, as a result.
    A last thing that occurs to me is, if I could test the ABS sensor without too much labor before doing anything else, if it's good (or if it's bad and I replace it but the ABS lights stay on) I could tell the dealer I know it's not the sensor, must be the bearing.
    What would you do?
    Thanks for reading this long post!
    #1 Minty, Oct 6, 2024
  2. Minty
    Minty New Member
    New York
    2018 Prius Prime
    So, update: I’ve been looking into types of ABS sensing systems. It looks like for different cars the part that rotates and is sensed by the sensor can either be a toothed metal ring, which can be in the driveshaft or on (or in) the bearing itself, or can be that circular magnetic strip that is on only one side of some bearings. I found a photo of a driveshaft, allegedly for a 2007 Prius. You can see a toothed ring between the CV joint boot and the splined spindle. If that is the ring for the ABS sensor, and all 2007 Prius’ have that, it seems to me that we can eliminate the dealer’s putting on the bearing backwards, since the sensor ring is not even on the bearing, so putting the bearing in backwards would make no difference to the ABS.
    Anybody know if that’s the case, that the backwards bearing possibility might not apply to this car?
    P.S. How can I attach a photo to a post directly from my photo library in my phone? I clicked on the photo icon but it asked for a URL. Thanks, new to this site.
    #2 Minty, Oct 7, 2024
  3. bisco
    52,348
    perhaps the mech simply didn't tighten something properly and it has loosened up
  4. fragglestickcar
    92
    49
    New York
    You won't go broke expecting the absolute worst from people, but that's a really tough way to go through life.
    Dealerships charge exorbitant rates, true. But you could take the glass-half-full interpretation and say their white-glove profit
    margins let them burn a few man-hours to correct an error, something a chop shop would be more loathe to do.
  5. Minty
    Minty New Member
    New York
    2018 Prius Prime
    Yes fragglestickcar, that makes sense and I thought of it, too. It would be more of a drop in the bucket for a big dealer to correct a mistake than for a little guy, and they might realize that correcting a mistake honestly could earn a customer for life. I also realize the other advantages of dealers: OEM parts, loaner cars, expertise on that make specifically, not to mention free coffee and occasionally donuts.
    After my long post I'm suspecting that in this case putting the bearing in backwards might be off the table anyway - which would be a big relief -- if, as I mentioned in the follow-up post, the 2007 doesn't even have the magnetic disk on the bearing that would be the culprit in a backwards bearing, but a ring on the axle instead. (In which case I have been suspecting the dealer of making a mistake they couldn't have made! Hope so.)
    Anyone with direct knowledge of whether that's the case on a 2007, please weigh in.
  6. Mendel Leisk
    41,858
    Try the "Upload a File" button (below edit window), then choose photo gallery or similar, click on a photo and click "add".
  7. Minty
    Minty New Member
    New York
    2018 Prius Prime
    Thanks, Mendel Leisk!
  8. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,093
    Columbia, SC
    Yes, I've replaced a handful of front wheel hubs on 2004-2009 Prii.
    To start with, I doubt anyone, including the dealer would actually do a bearing replacement instead of just replacing the hub. It comes as a complete assembly, so there's no dicking around with pressing bearings in or out, etc. Labor wise, and material wise, it doesn't make sense. If anything, they may have not correctly aligned the dust shield window with the abs sensor so the sensor can correctly see the tone ring. Maybe even some debris got on the sensor.
    All dealers provide some warranty on their work. Take it to them and let them check it out.
  9. Minty
    Minty New Member
    New York
    2018 Prius Prime
    Great info! That nails it. (And my daughter says the receipt says they replaced the hub too.) And now I even know what you’re talking about with the tone ring and the hole etc. whereas a day ago I’d have had no idea.
    She’ll just head back to the dealer (but now with a little more knowledge). Free coffee, too.
    My first time on this forum. But so far so good!
    #9 Minty, Oct 7, 2024
  10. highmilesgarage
    highmilesgarage Active Member
    489
    180
    Kansas City
    the Prius is not a pressed in bearing type and the bearing don't have a magnetic strip for the ABS sensor. It uses the tooth in the CV axle for the ABS sensor and usually the hub as an assembly is replaced (too much work to replace the bearing only) No way it's installed backwards, however there's a cover that needs to be aligned and that could cause issues. The cover just snaps in and could fall off or your ABS sensor just died. Why not bring the car back to the dealership to address the issue?
    I just did the wheel bearing on my 06 Honda Pilot this weekend, I just hoped that it's the hub type but it's the pressed in bearing.. too much work but really cheap replacement.
    Danno5060 likes this.
  11. Minty
    Minty New Member
    New York
    2018 Prius Prime
    Yup, thanks highmilesgarage and TMR-JWAP, back to the dealer it is.
  12. Danno5060
    Danno5060 Active Member
    394
    201
    Wyoming
    I used to have a 2009, so I looked it up - the same wheel bearing/hub assembly works on 2005-2009 models (43510-47012). The speed sensor tip goes through a hole in the steering knuckle as well as a hole in the dust cap.
    When the local dealer replaced a wheel bearing, they didn't get the dust cap fully seated in place, so a week later it popped off. This destroyed the speed sensor and tone ring on the CV axle in less than a second (along with making a horrible noise). The dealer also refused to cover the repair and quoted me $1400 (I think) to fix the problem they caused. I told them I couldn't trust them to repair my car (or anybody else's for that matter.)
    The way that dust cap just presses into place inside the wheel bearing doesn't seem like the most robust engineering to me. I don't know how others do it, but I suspect that many just leave the dust cap off when replacing the wheel bearings. For me, I developed my own process of seating the dust cap in the bearing using the CV axle and some electrical tape. I also clean up the part of the dust cap that seats inside the bearing/hub with some blue Locktite (being careful not to get any inside the bearing).
    It's normally fairly easy to pull the speed sensor (10 mm socket) If they changed the wheel bearing recently this shouldn't be a problem. You can check out some potential problems when you do this. First, check the tip of the sensor for debris (it's magnetic and can attract all sorts of particles, which would cause a sensor alarm). You can also shine a light into the hole and see if the hole in the dust cap is aligned with the steering knuckle. Also, you might also somewhat see if the tone rings on the CV axle are intact (you won't get a clear view, but if there's a major problem, you might be able to see).
    Other than that, I agree that it's a crappy mechanic, with an unbelievable excuse.
  13. Minty
    Minty New Member
    New York
    2018 Prius Prime
    @Danno5060 hopefully we’ll have a better dealer experience.
  14. mr_guy_mann
    mr_guy_mann Senior Member
    4,086
    1,997
    NJ-USA
    So the front wheel bearing is an assembly that bolts to the steering knuckle. Can't put it in backwards. As you discovered with your research, the Gen2 Prius uses a "variable reluctance" wheel speed sensor with a tone ring on the axle. It produces an AC voltage signal.
    Other cars (like Hondas) use a "magneto resistive" sensor with a magnetic encoder as part of a separate bearing. (You can press those in backwards). The electronics in the sensor produce a digital signal.
    As far as what your problem is, it would be useful to know what the trouble code is. Then we could give better advice instead of guessing.
  15. Minty
    Minty New Member
    New York
    2018 Prius Prime
    @mr_guy_mann here are photos of the printout. Actual codes are on second page.
    #15 Minty, Oct 11, 2024
