Knocking zone coming from steering over bumps
Discussion in 'Gen 3 Prius Technical Discussion' started by douglasjre, Oct 4, 2024.
  1. douglasjre
    douglasjre Senior Member
    2,173
    716
    Null, NL
    Rumor has it that there's a plastic star gear at the bottom of the steering column, but the parts diagram doesn't show that part. I already replaced all the tie rods and lower control arms but that sound is still there over bumps and can be reproduced when jiggling the wheel back and forth. Any opinions?
  2. Pete44
    Pete44 Junior Member
    48
    Those look really good. I have a torn rubber boot on my upper sway bar link on one side. Don't know how bad this will prove to be on the joint, but will replace someday if it starts having a problem.
    The springs do "look" better on the new struts, but I wonder, since springs can look identical and have very different spring-rates, if they're just more coils of metal to get a similar spring rate to OEM's. The couple of pounds isn't much of a difference, which is good, and those look great....just wonder how the springs will hold up compared to OEM. They might be better.
  3. ASRDogman
    ASRDogman Senior Member
    7,555
    3,900
    Wheel bearing, or tie rod end, inside and/or outside.
  4. Eddie25
    Eddie25 Active Member
    497
    209
    MI
  5. douglasjre
    2,173
    716
    Null, NL
  6. Eddie25
    497
    209
    MI
    I thought it did, but I'm not sure. My issue was the bolt.
