What broke in this picture?
Discussion in 'Gen 3 Prius Technical Discussion' started by douglasjre, Oct 9, 2024.
  1. douglasjre
    douglasjre Senior Member
    2,173
    716
    Null, NL
    Screenshot_20241009-022738.png Pulled the steering column apart to try and find whatever is loose causing a knocking over bumps and reassembled. It all turned the wheel and something snapped and now the horn doesn't work. Pulled the hornet off. It's still connected but it looks like something in here is must be broken. Car is throwing codes. Haven't had a chance to pull them yet. Which one of these parts has the clock wire?
  2. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,091
    Columbia, SC
    If memory serves correctly, 84306 should be the clockspring assembly
    douglasjre likes this.
  3. JC91006
    JC91006 Senior Member
    16,765
    8,563
    Here is a video on what could be causing the rattle over bumps. Steering column bushing
  4. douglasjre
    2,173
    716
    Null, NL
    I just got a report that now the windshield wipers don't work either. Do you think that one assembly will be enough or is there the assembly behind it for the windshield? Wipers?
    I've also got a picture of the trouble kids attached. Not sure what to call this if I get it from the used car part supplier like trq PXL_20241009_121920628.jpg
