Radiator replacement.
Discussion in 'Gen 2 Prius Main Forum' started by Prius92, Oct 10, 2024.
  1. Prius92
    Prius92 Active Member
    581
    120
    Iowa
    Replacing the old one, the new one does not any hardware to hold it together.
    There should be two nuts installed on the top and bottom to hold it to the support mounts.
    Mine doesn't have them.
  2. Mendel Leisk
    41,011
    And presumably the old nuts are missing?
  3. Prius92
    581
    120
    Iowa
    Too rusted out to use.
  4. Leadfoot J. McCoalroller
    8,017
    7,494
    Pennsylvania
    2018 Prius c
    It's normal and expected to re-use fasteners when replacing parts.
    If the fasteners cannot be re-used, it is normal and expected to have to buy replacements separately.
  5. mr_guy_mann
    mr_guy_mann Senior Member
    4,021
    1,950
    NJ-USA
    I replaced the radiator on my 06 last year. Purchased everything from Toyota. Radiator, all hardware, hoses, clamps, fan switch, A/C condenser, etc.
    I tested the fans before the work to see if I needed them as well - mine were fine.
    Just wanted to go in once and be done
