How to calculate mAh capacity of a single module
Discussion in 'Gen 2 Prius Main Forum' started by rogerdpack, Sep 17, 2024.
  1. rogerdpack
    rogerdpack Junior Member
    62
    Enoch, UT
    There are modules for sale on (ex: ebay) that say "4K mAh capacity" or what have you. I tried to ask people how they calculated that and they seem to say "we put it on the charger, cycle it, and the charger reports this capacity number" LOL. So...how is this number calculated by chargers, anybody's guess? Do they max out voltage then run it down to a certain voltage, and use that? Is there a common way to calculate it? Reason being is I want to buy one that kinda matches my current modules as a replacement (for a bad module) but not sure how to measure capacity of my modules to \see how they compare...
    Thank you :)
  2. PriusCamper
    PriusCamper Senior Member
    11,978
    4,870
    Pacific Northwest, USA
    Well... I always say the rebuilders that spend tens of thousands of dollars on lab grade electronic systems to measure cell capacity do it much more accurately and efficiently, and that hobby chargers and dischargers aren't very accurate because they can't be calibrated / fine tuned.
    But then @TMR-JWAP will come along and explain that he finds hobby chargers accurate enough and his methods seem fairly straightforward.
    If you're just trying to buy high quality used modules that aren't junk than buy from professor Joe. He not only has spent a fortune on battery rebuilding gear over the decades, but he teaches hyrbid and EV cars at the local college: Hybrid Car Battery Distributor | Contact Us | 2nd Life Battery
    rogerdpack likes this.
  3. MAX2
    MAX2 Senior Member
    1,436
    481
    101
    Third planet from the Sun
    Battery capacity is the ability to give off an amount of energy per unit of time.
    It is accepted that the battery has upper and lower voltage limits.
    For a nickel-metal hydride battery module, energy is given off within the voltage range from 8.4 V to 7.2 V.
    It is dangerous to charge above 8.4 V due to the boiling of the electrolyte and the destruction of the shell due to pressure.
    The lower voltage limit of 7.2 V sets the limit after which the battery quickly loses its quality characteristics and becomes waste.
    You can measure it using a car lamp by connecting it to the positive and negative terminals of the module.
    You will need a voltmeter to monitor the voltage, an ammeter to measure the current and a stopwatch to measure the time.
    If your module is discharged from 8.4 V to 7.2 V within one hour, and the current is equal to 5 A, then the capacity of the module will be 5 A * hour.
    If the module is discharged in 45 minutes, the capacity will be 5A*3/4 hour=3.75 A*hour
    Since the lamps can be of different power, the current must be measured in each case. In addition, the current may drop during discharge.
    Then it is more accurate to measure the current over short periods of time (5-10 minutes) and sum up the values.
    For example: 6A * 1/6 hour + 5.8A * 1/6 hour + 5.4A * 1/6 hour + 5A * 1/6 hour
  4. PriusCamper
    11,978
    4,870
    The one variable that's hard to account for is heat throughout the entire circuit, especially when you have fans keeping things cool. Expensive equipment is calibrated to have accurate readings based on heat issues, cheap equipment is not...
    Especially the temperature of the filament in the bulbs change the resistance and a dim bulb is a different resistance than a bright bulb, so lab grade gear uses resistors that don't vary in resistance. Of course I like the way the lights light up a wall and let me know with a click glance how things are going with each module with a volatge meter giving more clear details for each module.
    Also NiMH is extraordinarily durable without damage even if you discharge down to 0 volts. I used to worry so much about that until I fell asleep once and 7 modules sat at 0-volts and was continually discharged by bulbs for 8 hours with no ill effects afterwards.
  5. ChapmanF
    17,176
    Whether using a bulb or a resistor, the discharge current will change over the duration of discharge, as the voltage drops. That isn't a problem if you have a good ammeter datalogging the actual current the whole time. Then you just numerically integrate to find the area under that time-current curve from the fully-charged to the fully-discharged condition, and that's the amp-hour capacity. The bulb and the resistor will give that curve different shapes, but the usual techniques for finding the area beneath work either way.
    Or you could build a constant-current circuit to discharge with, and then finding the "area under that curve" is trivial because it's rectangular and you just multiply the constant current by the hours it took from the fully-charged to the fully-discharged points.
    When comparing results reported by different people, it's important to find out what criteria they used for the fully-charged start point and fully-discharged end point. For example, 7.2 volts suggested in #3 is the nominal voltage for a module (1.2 V per NiMH cell). Some people will use 1.0 V per cell as a discharge cutoff. Different choices there will lead to different capacity figures.
    rogerdpack and PriusCamper like this.
  6. rogerdpack
    62
    Enoch, UT
    Interesting. Thanks for the replies!
  7. rogerdpack
    62
    Enoch, UT
    I can confirm some ebay sellers seem to measure capacity from "full" down to something low like 1.0V (which can inflate it it by like 3.5K mAh)...some go down to 5.0V. Many have no idea how they calculate it, but you can ask them if they know how they calculate.
    Is there some kind of "industry standard" way to measure capacity, like from "full" down to 6.0V or anything like that, anybody have an inkling?
    Also when "new" modules are listed as 6.5 Ah I wonder how they determine that...based on
    it's not by calculating from "full" to 7.2V ...which is only like 2700 mAh...
    #7 rogerdpack, Oct 10, 2024
  8. rogerdpack
    62
    Enoch, UT
    According to How to measure capacity of a 3S NiMh battery? - Page 1 the "ANSI" procedure for NiMH is to basically charge to "full", then discharge to 1.0V (so for prius modules, 6.0V).
    Not to mention I discharged a cell to 2.0V recently and it appears to have killed it...
    So I wish I could propose that as some kind of standard to the greater prius community as well :)
    #8 rogerdpack, Oct 15, 2024
  9. rogerdpack
    62
    Enoch, UT
    Dang, it won't let me edit or delete my earlier message after awhile :|
    Anyway I should clarify I took a module to 2.0V @ 1.5A and that I think the amps killed it. Both "hybrid automotive" and battery university recommend "slower discharge" after reaching 1.2V (6.0V for a module) BU-807 recommend discharge down to 0.4V (2.4 for a module) as well. So probably my fault, not a problem with the low voltage per se.
    The hybrid automotive recommendations seem to recommend 0.18A for a module, for instance (Light Bulb Discharger User Guide – Hybrid Automotive 140V 25W bulb)
    See also https://electronics.stackexchange.com/a/728022/86540
    #9 rogerdpack, Oct 15, 2024
