FOR SALE - 2013 Toyota Prius
Discussion in 'Prius Cars For Sale' started by Spoke Said, Oct 16, 2024.
  1. Spoke Said
    Spoke Said New Member
    SE Washington
    Miles: 232,350
    Condition: Everything works except for the head gasket.
    Details: This 2013 Toyota Prius in blue is a fantastic project for any DIY mechanic or someone looking to save on a hybrid. With a solid engine and all features in working order except for the head gasket, it offers great potential once repaired. Perfect for someone who loves to tinker!
    Style/Body: HATCHBACK D
    Engine: 1.8L L4 DOHC 16V HYBRID
    Country of Assembly: JAPAN
    Clean title in hand
    Make offer
  2. Ronin416
    Ronin416 Junior Member
    Fresno
    Where is this car?
    iPhone ?
    SE Washington
    Walla Walla, WA
    SE Washington
  5. Thomas Zak
    Thomas Zak Junior Member
    Los Angeles
    How is the interior?
  6. Ronin416
    Fresno
    SE Washington
    It's good. Normal wear, no tears. Working on getting some additional pictures up today.
    SE Washington
  9. Thomas Zak
    Los Angeles
    Does it have a genuine Toyota catalytic converter or aftermarket replacement? This is very important as I'm going to need to be able to pass California smog. They require original cat to be in place, so please don't guess if your not sure.
    SE Washington
    Color
    Previous owner said it was repainted this blue for his wife. It is red under the blue seen from engine compartment. I'm not a paint professional - seems rediculous to get blue detailed throughout the enigine. See image attached... IMG20241018123624.jpg The top has an alternate colour from a repair where they couldn't match the other. See image...
    Catalytic Converter
    The short answer: Unknown.
    The other answer: The owner before me had it licensed in Portland, OR. So, it would have had to pass DEQ there. I had a cat security shield installed and peeked underneath. Nothing seemed to scream anything other than original. Of course, I am not an cat professional either.
  11. ETC(SS)
    7,130
    Bump.
    You may want to list a floor bid since you do not say how much you want for the car.
    Also consider parting it out or giving it to a charity for the tax break.
    I'm presuming that a $500 opening bid would be rejected out of hand - so lookers on might be interested in that.....or a follow-up bid.
    $1000, for example 'might' (would!) be too high for me and too low for you since I would have to have it towed 10 states away and then spend a zillion hours replacing the head gasket and THEN replacing the parts that caused the head gasket to fail.
    Also - has it hydro-locked yet?
    That would necessitate a total engine replacement.
    The way to tell is whether or not it still starts up - but beware that this is a test that you can only do a few times before you can't.
    The interior presents as normal for a 235K mile, 12 year old car - but what about smoking/pets?
    Trim level?
    You may want to take pictures of the wheels/tires since they represent a non-trivial percentage of this car's real-world value.
    KBB says your car may be worth:
    BUT(!!!) you're going to want to back out about $2,000 for the engine replacement/repair.
    Good Luck!
