Trying to understand INF codes (paperclip method for retrieving codes)
Discussion in 'Gen 2 Prius Technical Discussion' started by Tynyyn, Oct 16, 2024.
  1. Tynyyn
    Tynyyn Member
    109
    29
    Bella Vista Arkansas
    I went out to my '04 Prius to pull the codes via the paperclip method. What I got was good stuff with some head scratching stuff.
    The ((!)) codes were 41, 49, 57
    The ABS codes were 42
    The Air Bag codes were 51, 53
    Looking at a thread with the codes displayed It seems there were no codes for 51 or 53. Hopefully someone can chime in and show them.
    41 seems to be Brake Actuator Assembly....Rear Increasing Pressure
    42 Skid Control ECU....................................Solenoid Left Hand Malfunction
    49 Skid Control ECU.....................................Rear Decreasing Pressure
    Harness and Connector
    I couldn't find explanations for codes 51 or 53 but I did see codes for 501 and 503 and 305.
    501 Initialization of Linear Solenoid...............Linear Solenoid
    503 Valve and Calibration Undone.................Valve offset learning undone
    305 Foreign object is attached........................Left rear speed sensor
    on tip of rear speed sensor Left Hand
    Here is a link to the trouble code explanations:
    Brake, ABS,VSC, (!) warning lights on | Toyota Prius Forum
    About a year ago I had the brake accuator replaced with one from a junk Prius. I didn't have TechStream to bleed the brakes so I had to take it to a guy who is a Prius Whisperer and he did a good job. Recently my Prius began having Christmas tree light problems. I put it down as a bad HV battery thus I replaced the HV battery. I had bought Dr.Prius' app and it showed I had two cells going bad. Thus I figured that was the reason the Christmas tree lights appeared on my dash. I'm glad I got a new battery because it showed to me that the corrosion on the battery terminals could have been causing some voltage drop. Lots of green corrosion on the copper plates. Got the new battery put in and the same lights came back on. So I pulled the codes with the paperclip method and was wondering if the accutator was going bad or if I had some debris on one of the ABS sensors. Maybe one of you guys could guide me on a course of action.
    BTW, I know a lot of you are shaking your heads at my reluctance to purchase TechStream but I have looked into it. I went to EBAY and it showed some cables that connect to the car and a lap top, yet I was wondering if the TechStream app comes with the cable or is it a stand alone purchase? The cost is anywhere from $30 to $70 so any info you can shed on that would be most helpful. Would you trust an EBAY version of TechStream or is there a better supplier?
    Thanks.
  2. ChapmanF
    18,558
    The "paperclip method" (which is detailed here: Blink (a/k/a Flash) Codes – How to. | PriusChat) gives you two-digit equivalents for many basic DTCs (diagnostic trouble codes, which have five characters when you read them with a scan tool). The repair manual shows which DTCs correspond to which two-digit blink codes. Sometimes it's easy, as for most of the heater/air conditioner codes, where a DTC B14xy has the blink code xy. But for many it's not easy like that, and you just have to look in the manual (and for brake codes, make sure you're looking in the right place of three different places, as that page linked above explains).
    INF codes are a whole different matter: they have three digits, and there is no blinky way of getting them. You only see those with a scan tool.
    Brian1954 likes this.
  3. mr_guy_mann
    mr_guy_mann Senior Member
    4,089
    1,997
    NJ-USA
    You could research alternative scantools. Genuine Techstream is a software subscription from Toyota. X dollars for Y days of function.
    Any other "Techstream" on the web is some type of pirated version that's been hacked to bypass the activation key.
    How well any one version will work - who knows?
    The other variable is the Vehicle Communications Interface - the usb cable that connects the laptop to the car's OBD port. Official cables are $$$ but "always" work. There are "pretty good" alternatives but still are $$.
    Then there's the (really) cheap cables on ebay and amazon - clones of a clone of a decent AfterMarket cable. Sometimes work, sometimes not so much.
    Or, you can look at the sticky thread near the top of this forum that reviews several OBD2 scantool apps and VCI devices for smartphone. Some are limited or specialized. Some are more capable and can scan all systems on a Gen2 Prius. A couple can retrieve INF codes.
    FYI, the Autel AP200 is being phased out (?) - replaced by the AP2500 (or AP2500E).
