2015 1.8L rattling at low rpm, head gasket?
Discussion in 'Gen 3 Prius Main Forum' started by stokesey, Oct 19, 2024.
  1. stokesey
    stokesey Junior Member
    71
    Southern Cal
    The car has 270k miles, it's rattling quite a bit at cold starts. I know 3rd gen Prii have issues with head gaskets, but I'll clean the EGR if I can get the dang thing off. Those bolts aren't fun:mad:. Also, didn't the gasket issues get solved in the later Gen 3s?
    Also going to swap coils and plugs as those were super cheap online. I have a head gasket test kit but I can't seem to find a radiator cap on the car. Maybe I could install it on the coolant reservoir? It's hard to keep the engine running and hold the tester in place. Rock on the gas might work...
    Thanks for any advice
  2. Tombukt2
    13,520
    2,433
    You need to stop running it while it's rattling All that's going to do is create you cracking the girdle down below the exhaust manifold and then the engine's toast so don't run it rattling park it stop it or something. If you're going to try and save it you can pull the spark plugs early in the morning and see the water droplets on the offending cylinders generally but don't drive it or let it run rattling if you can force clear it up by stepping on the gas you can let it run a little bit while force charging the hybrid battery every so often while you figure out what you're going to do but I wouldn't be driving it rattling and all that it'll just ruin what you have and dictate a complete engine change.
  3. Mendel Leisk
    41,971
    How long have you had it?
    Hang onto the old ones...
    With your miles and symptoms, I'd go straight to head gasket assessment. EGR cleaning is always worthwhile, but head gasket should be first priority.
    That's probably the one that tests for exhaust gas in coolant. At least at the beginning of head gasket failure, it's been coolant leaking into combustion chamber. For a DYI'r boroscope inspection the combustion chambers will likely better. Look for one cylinder (typically starts cylinder one, which is to your left stand at front) that's got exceptionally clean cylinder top, and/or pooling coolant atop piston.
    #3 Mendel Leisk, Oct 19, 2024
    stokesey likes this.
  4. Higgins909
    Higgins909 Member
    277
    68
    You use that head gasket test vial on the coolant reservoir to the left. The engine coolant reservoir. Next to the dipstick.
  5. rjparker
    10,612
    6,655
    It is always amazing how we humans hate to accept the obvious and are willing to spend good money without doing a diagnostic that is widely accepted to be definitive.
    Egr won’t cause this. Even if it is stuck open. A stuck open the will cause stumbling but not severe rattling. If you must spend time here block off the path between the egr valve and intake pipe.
    No
    Those parts are more likely to add problems. A bad plug or coil will continue to misfire as the engine warms up, not just at engine startups.
    A combustion coolant test is definitive if it indicates a hg fail. A pass proves nothing on these engines. You need to put the car in maintenance mode to keep it running or simply have someone hold the gas pedal down.
    The definitive test is a quality dual view borescope.
    Shudder video
    “Hey Walt… they want to wait and see if it gets worse…”
    Car Care Nut HG Borescope at 7:40
  6. stokesey
    71
    Southern Cal
    Thanks for the responses. I'll run the car in maintenance mode and do the head gasket test on the coolant reservoir. I understand that rather than coolant contamination, the symptom of cooked heads is coolant loss into the combustion chamber.
    I saw a guy on YouTube who pulled his coils and spark plugs then held sheets of paper over the engine while a helper cranked the engine. There were coolant stains on the paper over cylinder 2, which he said is a common place the gaskets leak. I'll give that a try and maybe scope the cylinders if they look nasty.
    Not sure where people got the idea I'm running the Indy 500 with the car or not diagnosing it. If I'm taking off the wipers and cowl to pull the coils and plugs, I may as well replace those parts as they have at least 150k of wear on them. For $60 a new set of plugs and coils is a no-brainer even just for the labor to pull them.
    I've used cheap coils before, they're fine for 20k miles or more.
    I also ordered the head gasket and bolt set. I prefer to have parts around before I really dive in. Based on my cursory inspection of EGR I can see that it's kinda tight in there.
    The computer has permanent OBD codes for misfires on cylinders 2,3,and 4 so I think the coils and plugs are worth it even just to diagnose further.
  7. stokesey
    71
    Southern Cal
    I see there is a young man on Youtube who pulls his Prius engine in an hour. JDM engines are $1500 or less for this car. I wonder why people are rebuilding so much with a decent supply of these engines around?
  8. rjparker
    10,612
    6,655
    OEM plugs have been known to last 200k miles or more. Coils usually last for the vehicle’s lifetime. Multiple cylinder misfires is a symptom of the engine losing sync with the electric motors in the transaxle. Coolant loss is only in advanced late stage Prius head gaskets.
    Keep your oem parts.
    Mendel Leisk and stokesey like this.
  9. Eddie25
    Eddie25 Active Member
    503
    212
    MI
    I think this is the wrong way to look at this. If you purchased cheap parts from a marketplace site, then they are counterfeit or crap. You are just making things worse. 20k or more is a crazy standard to judge something that should last 200k or more. If you must, get real Denso or NGK iridium spark plugs and just wait on the coils.
  10. stokesey
    71
    Southern Cal
    Video of a cold start:
    I ran the head gasket tester on the coolant reservoir. No temp gauge on dash so I may need to pull it up on a scan tool. Pretty sure I hit operating temp after 10 minutes at 2500rpm. Indicator fluid turned greenish (from blue), but not yellow. I'd say if there are hydrocarbon gases in the coolant, it's not much. Still not great obviously.
    When I pull the plugs I'll do the paper over the plug wells test. I did find a scope laying around so maybe I'll post some vids of the cylinders and pistons if people are interested.
    If I get coolant out of the plug wells, the cylinders are cleaner than expected, and new plugs and coils don't do anything for the problem, I'll rule it a blown head and will be sourcing a JDM engine for the car. No point in doing this head gasket repair on a 270k mile engine.
    If the cylinders have normal wear and no coolant blowing out of the plug well, I'll finish cleaning up the EGR and intake, and will run it with new plugs and coils for a bit.
  11. rjparker
    10,612
    6,655
  12. stokesey
    71
    Southern Cal
    Generally when people post to automotive forums they are looking for help. I'm all for jokes about blown engines, but I actually want to get useful information from community members who know this engine. I also like to try to contribute to the community by reporting my findings, in the hopes that others who find themselves in my situation will have an account of what was done and what the resolution was.
    Is anyone interested in my findings? I have the results from a compression test and some videos of my cylinders. Thanks.
  13. stokesey
    71
    Southern Cal
    Had the car 2 weeks. Its been driven 3 miles. Cylinders do look somewhat different, 1 and 4 are clean, 2 has some debris in it, and 3 looks charred. Compression is 120psi across the board. Spec is either 118psi or 190psi depending on where you look. All data says 118, manual says 190.
  14. Frontporch
    Frontporch Active Member
    536
    122
    Nj
    I am going to follow your thread here. I am in the same boat as a new owner of a Gen3 and have lots of maintenance to go through before it hits the road, but I don't have the rattle on startup. Keep this updated with your progress.
    My guess is the shiny pistons have been steam cleaned with coolant. I would expect a normal engine to look pretty dark and charred, but have never seen the inside of a Prius. I like the decision to go with a new motor if you already have close to 300K miles. I am at 180K and would probably attempt a head gasket.
  15. stokesey
    71
    Southern Cal
    Welcome to the thread. What year Prius do you have, and do you have the 1.8L 2ZR-FXE+3JM engine? My understanding is that the head gasket design WAS changed in 2014, causing less cooked heads in 14/15 models.
    The rattle is quite scary, but I believe people panic when it happens because it looks like what would be a SERIOUS engine problem on any other car. The clutch between the electric motor and the gas engine amplifies what might just be a bit of misfiring on the gas side. Of course it could also be the head, but assuming it's the head is a mistake in my opinion.
    If you do end up doing the head gasket, make sure you resurface your head, replace the bolts, and replace EGR/PCV and clean your intake. Many people on the forums do their heads and don't get it quite right.
    I've got 120psi on all 4 cylinders so I don't think my head is blown. Yet.
  16. rjparker
    10,612
    6,655
    The significant change in mid 2014 was improved pistons and rings to reduce excessive oil consumption and blowby.
    Ignoring an early hg rattle will leave you with bent piston rods or a hole in the block when it internally grenades.
    Best to minimize driving and get it fixed right away. Dealers and most pro shops highly recommend a rebuilt engine instead of a simpler hg job that they don’t want to guarantee.
    Shudder video
  17. stokesey
    71
    Southern Cal
    Also one last thing: this engine uses the Atkinson cycle (rather than the normal Otto Cycle in ICEs). Atkinson cycle - Wikipedia
    Basically the intake valves stay open a little later, resulting in less power but better fuel efficiency. Also there is a bit of blowback into the intake manifold. This could contribute to buildup in the intake, but could also create some turbulence in the intake. Just something to consider when diagnosing.
  18. stokesey
    71
    Southern Cal
    Well the head gasket doesn't rattle, the rattle is caused by the ICE running sub-optimally, which creates vibration in the Torque Limiting Clutch (aka damper). The electric motor that shares power with the ICE is used to start the ICE, so there is some normal vibration at start as the system adjusts the electric motor rotation to the speed of the ICE. Clearly if the ICE is stumbling and/or misfiring, this vibration will increase. However, this would explain the vibration occurring only at cold starts going away after running for a few seconds and/or spinning at higher rpms. Therefore I conclude that bad coils/plugs/EGR/PCV absolutely could cause this vibration only at start (or during normal driving as well). Finally, the torque limiting clutch could very well be worn. It seems that the springs on this part tend to fail occasionally.
    Based on my assessment, I suspect you're telling people they have a blown head when there can be many other root causes of the vibration. Repeating the jokes about blown engines likely just means more people doing unneeded head jobs or even junking their cars.
    I put in my $40 coils and my $20 plugs and the car is running fine after a full cleaning of the intake system. I'll measure the resistance of my old coils just because I'm curious if they're burnt out. The plugs were beyond toasted. I haven't had any vibration at start or any other time driving. In fact, I got the car up over 100mph and it ran smoothly.(y)
  19. Frontporch
    536
    122
    Nj
    Mine is a 2012 with 180K miles. Before I take it on the road I am going to thoroughly clean out the EGR system and Intake manifold, clean the throttle body and probably pull the plugs and do an inspection of the cylinders. Will do a PCV swap and maybe install a catch can.
  20. Frontporch
    536
    122
    Nj
    I believe the rattle is from hydrolock which results from trying to compress coolant in the cylinder instead of fuel/air.
