Prius V Hybrid Battery System Malfunction
Discussion in 'Prius v Technical Discussion' started by onlypurchases, Oct 23, 2024.
  1. onlypurchases
    onlypurchases Junior Member
    SF
    2015 Prius v wagon
    I’m in need of some help! I started to get the dreaded P0A80 error code on my Prius V. After thinking it over, we didn’t like the remanufactured battery options, but didn’t like the price of a new battery, so opted for a “low mileage” oem salvage battery. We don’t plan to keep the car much longer. It has 200k miles.
    I installed the battery, only to find the same error saying “hybrid system malfunction”. I swapped back to the original battery which is now giving me the same error code again, but I can’t even fire it up or turn it on now.
    I found a plug in the fuse box to “reset” the computers but it continues to have the same error.
    Is it possible I damaged something bigger swapping out batteries? It seems like the job was simple. A few plugs and a few screws. Not sure how I could have screwed this up.
    what should I do now?
  2. rjparker
    10,438
    6,545
    Hybrid batteries don’t like to sit unused for long periods so your salvage battery may have a dead or weak cell(s).
    The thing I might do is drive the salvaged battery for a week and see if the charge discharge cycles help it.
    Plus get a scanner or Dr Prius app to monitor the cells.
  3. Air_Boss
    Air_Boss Senior Member
    4,219
    1,188
    New Yawk
    You're sure you fully re-plugged and re-snapped the orange HV harness connector?
    Brian1954 likes this.
  4. Carall
    Carall Active Member
    316
    104
    Harrisonburg, VA
    I guess you have to bolt the battery to the car body.
