For Sale Gen 3 Hybrid battery for sale
Discussion in 'Private Sales' started by 419 Grease Monkey, Sep 14, 2024.
  1. 419 Grease Monkey
    419 Grease Monkey Junior Member
    24
    Houston, TX
    (1) Gen 3 hybrid battery for sale. Best offer in the next few months.
    Bought from Toyota brand new, installed into a 2012 with 220k miles after head gasket replacement, car gave network error code. Driven around block a few times, but otherwise new.
    Car being donated or scrapped, but the battery is too good to scrap.
    Paid $2800 after core charge, could deliver around Houston, TX, but don't have the shipping container for further. Also have a 4 ch. charger+ wires for checking/charging the individual cells if interested.
    Any other components off of a 2012 prius III available before its junked. Clean EGR, motor runs, just can't clear a network error code.
    text - four ate 0-seven 7two two3nine4
  2. 419 Grease Monkey
    24
    Houston, TX
    Correction, car has 250k miles
  3. bisco
    52,407
    don't forget the cat, they are worth a few bucks if oem
    419 Grease Monkey likes this.
  4. Mark B
    Mark B New Member
    Ventura
    2014 Prius v wagon
    Howdy, Tell me about the charger, please.
  5. jjmerp
    jjmerp Junior Member
    51
    22
    Ohio
  6. 419 Grease Monkey
    24
    Houston, TX
    bought the charger hoping it would fix the old battery, however, i just learned that all but 1 cell was below the minimum retention. I used it to charge the new battery i bought, following this guys procedure and it seemed to work.
    4 channel, so 4 cells at a time, over 28 cells.
  7. jjmerp
    51
    22
    Ohio
  8. douglasjre
    douglasjre Senior Member
    2,205
    736
    Null, NL
    Why would you scrap that perfectly? Good car
  9. 419 Grease Monkey
    24
    Houston, TX
    I am not a good enough mechanic to troubleshoot the U0100 code that it has.
  10. 419 Grease Monkey
    24
    Houston, TX
    $100
  11. 419 Grease Monkey
    24
    Houston, TX
    Vehicle sold.
  12. old_
    old_ Junior Member
    Nebraska
    Do you still have the charger? Is it the CQ3 model? Would you ship it?
    Thanks!
