How to erase P0420
Discussion in 'Gen 2 Prius Main Forum' started by Prius2006GuitarGuy, Oct 5, 2024.
Tags:
  1. Prius2006GuitarGuy
    Prius2006GuitarGuy Junior Member
    Sweden
    Hey!
    I have a AP200 and got a P0420 code, I am going to try two tricks one after the other to try to fix it:
    1 - clean the cat via "Liqui Moly Catalytic Converter Cleaner", even if it does not fix the problem the cat probably needs cleaning
    2 - use a spacer
    but how do I clear that p0420 code? I don't see that option in the AP200 but I know people clear these codes via some program...
    Thanks!
    Tombukt2 likes this.
  2. Tombukt2
    13,268
    2,396
    You want to use one of these stainless steel angle spacers that actually puts the O2 sensor parallel with the pipe not sticking out of the pipe sideways like it does now You don't want to use a spark plug fowl or adapter this thing you want to use is $18 has a piece of catalyst material in it and it swivels and locks at about any angle you want to set it in there You apply that to the bung or the hole that the O2 sensor screws in now and that's going to make your O2 sensor go from screwing into the side of the pipe to screwing in with the length of the pipe if you will then that space is you and changes the angle and slows down the response of the gas and material getting to the sensor to be scanned. Just look online eBay and everybody I have them in my drawer here sometimes they get used sometimes they don't and as far as clearing the codes with the AP200 you follow the procedure to clear the codes easily you just touch the code and then do a complete clear or whatever it's called and it'll clear all of those codes that it read a minute ago but you really want to check them first and do whatever it is you need to do before you wipe them out when the sunlight goes up I'll bring up my AP200 on the screen and tell you exactly what key presses to make to clear all the codes but it's right there in the instructions and it's on the screen it's kind of like every scanner you use almost as far as clearing the codes and then if you put the spacer in and you just drive the car two or three runs to the store and all if the PO420 is not detected again it I believe will clear the code by itself and it will become a stored code possibly so that if it does it again it can come back but it generally won't have the light on under this condition but getting the proper spacer is kind of key using a spark plug fowler like you see people doing they don't do very well they get red hot not made out of very good material etc could cause you more strife than not.
  3. ChapmanF
    18,447
    Do you still have a P0420 that shows as 'current' and lights the check-engine light? Or only a leftover P0420 code shown as 'permanent'?
    The 'permanent' codes aren't really permanent; they exist as a record that "hey, this problem was detected" but will go away eventually as the car is driven and passes the associated self test a few times.
    If you want to chase the permanent code away faster, you can flip to P0420 in the repair manual and drive the "confirmation driving pattern" shown there.
    Toyota Service Information and Where To Find It | PriusChat
    BiomedO1 likes this.
  4. AzusaPrius
    AzusaPrius Senior Member
    2,221
    929
    You can reset the code by disconnecting the 12v battery if your obd reader can not do it.
    Also try Cataclean it is very good and works.
  5. ChapmanF
    18,447
    Be sure first (review post #3) whether you're talking about a 'current' code (that lights the check-engine light) or a 'permanent' code.
    Disconnecting the 12V battery, or an OBD reader code clear, will clear a current code. Neither of those things will clear permanent codes. Those only go away when the car has been driven and passed its self-tests the right number of times.
    A code clear or battery disconnect can in fact take you backwards if you're dealing with a permanent code. You might already have driven enough to be close to the code going away on your next drive, but now you'll be back to square one.
  6. PriusCamper
    PriusCamper Senior Member
    12,980
    5,277
    Pacific Northwest, USA
    Isn't that for Gen 3 and not Gen 2? That's been my experience...
  7. ChapmanF
    18,447
    Hmm, yeah, permanent codes were a newer OBD-II thing that it looks like the gen 2 ECM hadn't implemented yet. DTC descriptions in the gen 2 manual still have "confirmation driving patterns" in them, but those seem to be only for the mode-6 readiness monitors, and not for clearing permanent codes in that generation.
    So presumably a gen 2 driver talking about a P0420 is talking about a current one, with the check-engine light lit.
  8. highmilesgarage
    highmilesgarage Active Member
    488
    180
    Kansas City
    save your money, those converter cleaners are a scam for SULEV (like the Prius) Buy a Powerball if you happen to have it fixed by using one of those cleaners. They usually go back and you buy again (and the cycle repeats..)
    you can try get a shorter spacer since the regular straight ones will hit the side of the exhaust channel, that's why it's preferred to have the angled (90 elbow) spacer. It works most of the time as long as your cat is not clogged.
    to clear the code, use the EOBD mode and clear codes.. if using Toyota module, select ECM and clear code.
  9. rjparker
    10,404
    6,519
  10. BiomedO1
    4,003
    2,103
    SacTown, Ca
    Check your local laws regarding emission control devices on cars. Your option #2 is considered tampering/bypassing the device and not repairing the problem. Where I live, local agency will withhold car registration making it illegal to drive on public roads; until properly repaired and recertified. A replacement CAT for a Gen2 is relatively cheap to replace, unless your laws require additional certifications for specific replacements of this type of emission control equipment.
    Hope this helps...
  11. Prius2006GuitarGuy
    Sweden
    Thanks for the replies guys!
    Tried again via the Autel ap200 and it cleared the code! The light has not come back on, I wonder if that will last...
  12. black_jmyntrn
    black_jmyntrn Senior Member
    1,728
    409
    2013 Prius Plug-in
    define shorter...
    shorter than this? with this one, it doesn't hit the side of the exhaust channel, just wondering if because no 90 elbow I am still getting the p0420
    https://black.jmyntrn.com/2024/10/26/p0420-dtc-and-my-gen-2-2009-prius-with-aftermarket-cat/
  13. highmilesgarage
    488
    180
    Kansas City
  14. black_jmyntrn
    1,728
    409
    2013 Prius Plug-in
  15. ski.dive
    ski.dive Active Member
    965
    244
    Hutchinson Island,FL. Mt. Snow,VT
    I installed the 90 bend last year... no more DTC code since!
    black_jmyntrn likes this.
  16. Prius2006GuitarGuy
    Sweden
    Cleared the code, added "Liqui Moly Catalytic Converter Cleaner ", engine light came on again :(
    Going to order that 90 bend and try that...
  17. rjparker
    10,404
    6,519
    The West Coast guys offer questionable advice on this subject. $15 down the drain. Even soaking a cat removed from the car does not work.
