2008 Prius randomly dies when driving
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by John k., Nov 3, 2024.
  1. John k.
    John k. New Member
    Kansas
    It's happened a few times at slower speeds where the car will restart while I'm driving and start in accessory mode and in park. I've checked both the inverter, inverter water pump, and 12v battery, all three work fine. What else could it be? It almost killed me by locking up the breaks at 65MPH
  2. Tombukt2
    13,270
    2,396
    You mean the ice engine returns to running whilst driving . In a different mode than just a second ago. ?
  3. saneesh8
    saneesh8 Member
    208
    52
    Allen, TX
    Loose connection somewhere? Any codes?
  4. bisco
    52,276
    any trouble lights?
  5. John k.
    John k. New Member
    Kansas
    No the car shuts off like if you cut all power then starts back up like if you pressed the power button twice with no brake
    Odd part, no
    Nope
  6. BiomedO1
    4,005
    2,105
    SacTown, Ca
    How did you test the inverter, inverter pump, and 12V battery?
    Is that a branded title car?
    has it been underwater?
    who did the maintenance on it?
    Any major work been done on it?
  7. John k.
    John k. New Member
    Kansas
    I did the tests you can find by searching online, and got the 12v tested at oriley's
    No It is not. Original title never been wreaked or anything
    Never been underwater
    I do most of the maintenance but I had someone replace my hybrid batts
    Other than the HV battery, no
  8. BiomedO1
    4,005
    2,105
    SacTown, Ca
    What's the warranty on that repaired pack?
    Was it a swap out or did they do individual battery/module replacements?
    Were those new or old replacement modules?
    Depending on your warranty, I'd probably take a peek inside that pack. Check for corrosion, especially at the connectors and HV safety disconnect.
    Even if there is a loose connector or corrosion in that pack, you should be throwing codes - because the 12V battery should be keeping the ECU alive. Check your battery ground points @ the frame. You seem to have multiple failure points. Check your wiring harness for vermin chew marks, heat related or corrosion on your wiring harness connectors. Use electrolytic grease when reassembling those connectors after inspection to prevent corrosion and moisture problems.
    #8 BiomedO1, Nov 5, 2024
  9. John k.
    John k. New Member
    Kansas
    No warranty
    Individual cells
    New
    I'll check the ground when I can
    Doing a break job tomorrow I'll take a look at the other stuff
  10. bisco
    52,276
    i wonder if there is an internal short in the 12 volt? you checked the connections and ground to body?
  11. BiomedO1
    4,005
    2,105
    SacTown, Ca
    There may be an issue with the start/stop button or ignition switch - but I really doubt it. It's easily tested by pounding around the button or rattling the key around to see if it kills the car.
    It could be just that simple.
    Just Rolled In - YouTube
    Enjoy!!!!
  12. John k.
    John k. New Member
    Kansas
    There is not, I found a random wire coming off of the ground of the car
  13. John k.
    John k. New Member
    Kansas
    I think it was the random wire I saw coming off the ground of my car
