BRAKE, ((!)), VSC, and ABS lights but no code, Days after Installation of Android Head Unit
Discussion in 'Gen 2 Prius Audio and Electronics' started by convoymose, Nov 13, 2024.
  1. convoymose
    convoymose Junior Member
    CA
    2026 Prius Plug-in
    XSE
    Anyone have issue having BRAKE, ((!)), VSC, and ABS lights but no code after installation of Android Head Unit. This 2 might not be related and might just be coincidence.
    Installed and replace Stock Stereo with an Android Head Unit like several days ago on a 2009 prius. Drove the car for morethan 100 miles without issue and this lights just came up today. Checked all fuse and they are ok.
    Inquiring here if anyone might have experience same issue, before I go into the Rabbit hole.
    Thanks in advance.
  2. dolj
    dolj Senior Member
    8,450
    4,291
    Wellington, New Zealand
    If you have these lights, you DO have code to read. If your code reader reports no codes, your code reader is inadequate.
    In all likelihood, there is no connection between your Android install and these lights on the dash.
    Get a good code reader so you can be informed of the real problem that you have now.
    Affordable readers that will work with your Prius are reviewed here.
    Brian1954 likes this.
  3. Brian1954
    Brian1954 Senior Member
    2,252
    895
    South Central PA, USA
    ^ +1
    The Autel AP200 is a good choice. $59 on Amazon right now.
  4. convoymose
    CA
    2026 Prius Plug-in
    XSE
    Thank you for the reply. And OBD link list. I have been using BlueDriver for OBD ever since and but yes not getting any codes back, dont think it goes through ECU or if it does very limited. AP200 seems to be good one on the list that reads ECU as suggested. Having my eye on that and as suggested by @Brian1954. Thanks again.
    By the way, I did however reset and remove the dash light via ABS reset procedure (OBD pin 4-13 jump) and 8 brake press within 5 sec. So currently dash is clear and good, if its really an issue and not just false alert should pop up again. Nonetheless this gives me something to work on to once I get the new OBD.
    Again much appreciated.
  5. convoymose
    CA
    2026 Prius Plug-in
    XSE
    Thank you. Just ordered it today.
  6. ChapmanF
    18,257
    Keep in mind that if you found that procedure somewhere, you also found how to get the codes (what the 4-13 jump is meant for, after all), so if the lights come on again, you'll be able to tell us what the codes are.
    Blink (a/k/a Flash) Codes – How to. | PriusChat
  7. convoymose
    CA
    2026 Prius Plug-in
    XSE
    Will do just that and thank you for the link. This made a lot easier to follow up on.
  8. convoymose
    CA
    2026 Prius Plug-in
    XSE
    Ok these light came up again today. @ChapmanF did the Flash/Blink diagnostic with the jump procedure and got the following:
    VSC - 45
    ABS - 42
    ECB ((!)) - 64
    Thankfully there are a lot of resources here in the forum and you just have to dig. VSC and ABS are just echo codes for what I have, and the root issue was ECB - 64:
    C1343/64 --- Rear Hydraulic System ---- Fluid leakage - Brake actuator assembly - Disc rotor
    RH Malfunction
    I had my rear brake assemblies changed (DIY) -- Brake drum, Shoes, and Wheel Hub assemblies, recently. So this actually narrowed my fix. Reset the light again hope this resolves it. Just incase and whoever might need it here is the link for the Blink codes and their corresponding Description https://attachments.priuschat.com/attachment-files/2024/08/255782_2006_PRIUS_RM_-_Blink_Codes_ABS_VTC_ECB.pdf
    Thanks again to all who chimed in and help, much appreciated.
