12V Battery Issues?
Discussion in 'Gen 5 Prius Main Forum' started by REBobBecker, Apr 1, 2024.
  1. I have had 12V battery issues with 2023-24 Prime
    15 vote(s)
    42.9%
  2. I have NOT had 12V battery issues with 2023-24 Prime
    20 vote(s)
    57.1%
  1. RandyPete
    RandyPete Active Member
    402
    167
    Santa Margarita, CA, USA
    2024 Prius Prime
    XSE
    Unfortunately reliability is not what you will get with the Gen 5 Prius Prime 12v Battery. Toyota engineers chose to implement a 12v Battery Management System that puts vehicle mileage efficiency first, and 12v battery reliability second. The stock 12v in the 2024 Prius Prime XSE is not a strong battery. As you search thru the posts here you will find that many owners have replaced the original battery either under warranty or at their own cost. After replacement the new battery soon becomes somewhat unreliable if the car is not driven daily, and with time becomes unreliable even if the battery is not driven daily. The new battery is still charged IAW the Battery Management System toyota engineers chose to provide with the car.
    In time you will get a battery maintainer device and maintain the battery periodically (either weekly or monthly) to get the reliability you want. Or you will continue to deal with Toyota dealership and your warranty to replace the battery more often than you would expect.
    Sad story indeed !
    LLuc and Brian1954 like this.
  2. RandyPete
    402
    167
    2024 Prius Prime
    XSE
    One thing you can do to help the battery perform more reliably is to never use the cars ACC mode. Put your foot on the brake and push the start button every time you are in the car. Don't listen to the radio or use any accessories on the car unless the car is in the Ready mode.
    GcinFl and Yvrdriver like this.
  3. reservoirblue
    reservoirblue Member
    92
    73
    Woodacre, CA
    2024 Prius Prime
    SE
    Not my experience. I've had my SE since March 24 without any battery issues. I've occasionally not used the cars for a few days, most recently it sat for16 days without losing any charge. I typically charge the "big battery" overnight.
  4. RandyPete
    402
    167
    2024 Prius Prime
    XSE
    How did you determine your battery "sat for16 days without losing any charge" ?
    Brian1954 likes this.
  5. Gokhan
    Gokhan Senior Member
    6,048
    2,400
    Paramount CA
    As it was already stated, it is impossible for the 12-V battery not to lose charge even in one day, let alone in 16 days. SOC drops by several percent everyday, and it would have dropped by about 50% or more in 16 days, and the battery would certainly completely drain in less than a month.
    However, there are reports that the Gen 5 Prius Prime charges the 12-V battery when it is plugged in. What I don’t know is whether this charging stops when the traction-battery charging ends, and then, the 12-V battery would drain even faster than as opposed to not being plugged in, due to the charging computer being on.
  6. reservoirblue
    92
    73
    Woodacre, CA
    2024 Prius Prime
    SE
    I have a radar detector connected which gives me a reading of the voltage upon start-up.
    To be fair, now that I think about it, I might have plugged it in the evening when I got back before driving the next morning, but I can't say for sure. I had left with the hybrid battery 75% charged.
    #26 reservoirblue, Nov 21, 2024
  7. RandyPete
    402
    167
    2024 Prius Prime
    XSE
    75% charger. What resting voltage was that before you put the car in READY mode (pushed on the brakes & pushed the power button) ?
  8. Gokhan
    6,048
    2,400
    Paramount CA
    Radar?
    When the car starts, the voltage you are seeing is the DC–DC converter voltage, which is always about 14.1 V at start, and it tells you nothing about the 12-V battery SOC. To get an idea of the 12-V battery SOC, you need to measure the rest voltage after at least twelve hours of sleep and with the car still sleeping (no key fob nearby).
    RandyPete likes this.
  9. RandyPete
    402
    167
    2024 Prius Prime
    XSE
    The easiest way to monitor the 12v battery voltage on a Prius Prime is to get a BM2 device and play with it on bluetooth app for your phone.
    Gokhan likes this.
  10. reservoirblue
    92
    73
    Woodacre, CA
    2024 Prius Prime
    SE
    Cobra-RAD-480i-Radar-Detector-Owners-Manual. ...
    Quadratec
    https://www.quadratec.com › sites › default › files
    PDF
    Battery Voltage. To display your vehicle's battery voltage, press the MUTE button while no signal is being detected.
  11. Gokhan
    6,048
    2,400
    Paramount CA
    OK, that won’t give you the battery (open-circuit) voltage but the DC–DC-converter voltage as the car needs to be on (or in the ACC mode with load on the battery). Therefore, it tells you nothing about the battery SOC. It is like measuring the alternator voltage in nonhybrid cars.
  12. RandyPete
    402
    167
    2024 Prius Prime
    XSE
    You just do not get it!
    If the car is in the RAEDY mode, you would be displaying the DC to DC battery charger voltage, not the resting 12v Battery voltage using tht method. It tells you nothng about the battery SOC or health. It just tells you whether the DC to DC device is working.
    reservoirblue and Brian1954 like this.
  13. reservoirblue
    92
    73
    Woodacre, CA
    2024 Prius Prime
    SE
    Sorry, above my pay grade. In a non-hybrid car, I'm assuming the voltage display once the "car electricity "is turned on does not speak to resting voltage or battery health either?
  14. Gokhan
    6,048
    2,400
    Paramount CA
    Correct, for a nonhybrid car, it is the alternator voltage, and for a hybrid car, it is the DC–DC-converter voltage. They are not the open-circuit voltage generated by the battery, but the voltage generated by the 12-V charging system.
    reservoirblue likes this.
  15. chris johnson 2
    chris johnson 2 New Member
    29
    Netherlands
    2024 Prius Prime
    Thanks for your several advices. Since I had the problem I have made sure to drive a good while every day and to be doubly sure everything is off when I leave the vehicle. I resurrected my jump leads which I had considered donating to the dump. I even ordered a modern battery powered jumper - wouldn't it be nice if Toyota delivered one with a new car instead of an umbrella! It might save them some money judging by the behaviour of the service guy who assumed the 12V battery was flat without even stopping to check anything.
    So far so good. Tomorrow I take the car to the dealer in Eindhoven, Netherlands, to test the battery they promise. I'll let you know how it goes.
  16. RandyPete
    402
    167
    2024 Prius Prime
    XSE
    What modern battery jumper did you order ?
  17. kiwiscoot
    kiwiscoot Member
    60
    30
    Christchurch New Zealand
    2019 Prius Prime
    I don't know if the Gen 5 operates like this but I found on my Gen 4 Prime that the car charges the 12V battery at 14.5V when the car is On and in Park. I will now every couple of weeks charge my car fully and after that switch it on and leave it in Park mode for a few hours. That way I know the 12V battery gets charged. Might be worth exploring on the Gen 5s.
  18. chris johnson 2
    29
    Netherlands
    2024 Prius Prime
    I ordered an Auronic 600A 7.200 MAh 4 in 1 with a bag for 63 Euros. lot of people had reviewed it positively.
    I took my car to the dealer and they checked the battery out using a program called Torque Pro running off the OBD2 Port I guess. Unfortunately I was not present when the test was done but the customer service told me they had filled the battery and charged it - it was not filled, whatever that means...
    I asked about jump leads and they said it didn't matter - everything should work. I found them very helpful and friendly. Hopefully I won't see them again until the first service.
    My Auronic should arrive this evening via DHL
  19. Mendel Leisk
    41,149
    Post #9 has the sole mention of “draw” in the thread, and that is using a clamp meter, which meant for measuring greater amperage values, not the milliamperes levels on modern cars that nevertheless can deplete the battery, in a matter of days, if excessive.
    If a few Gen 5 owners take the the time and effort to put a regular digital multimeter in series, between the neg battery post and ground, with the car closed and undisturbed, read-and-post the milliampere draw, it might be illuminating.
  20. MikeDee
    MikeDee Senior Member
    1,572
    596
    San Francisco Bay Area
    Deleted. Tapatalk has major issues with adding or quoting.
