Help- BRAKE,ABS,VSC- Warning Lights Came On=Mechanic said...
Discussion in 'Gen 2 Prius Main Forum' started by ski.dive, Nov 20, 2024.
  1. ski.dive
    ski.dive Active Member
    967
    245
    Hutchinson Island,FL. Mt. Snow,VT
    BRAKE- ABS- VSC- Warning Lights On
    Mechanic said he read 'the Code' & it had something to do with 'Drivers side Rear Brake'
    He thoroughly checked the 'Drivers side rear brake' and found nothing wrong- He was not concerned
    *Now 400 miles & 3 weeks later the=BRAKE- ABS- VSC- Warning Lights came Back On again
    The Prius is driving & braking fine?
    ---*What are some of the things on 'Drivers side rear brake area===
    That will cause the BRAKE- ABS- VSC- Warning Lights to come On
    #1 ski.dive, Nov 20, 2024
  2. Brian1954
    Brian1954 Senior Member
    2,402
    962
    South Central PA, USA
    List the actual trouble codes, and you may get some help.
  3. bisco
    52,388
    the mechanic does not have a prius aware scanner
  4. highmilesgarage
    highmilesgarage Active Member
    493
    182
    Kansas City
    or just clueless.. a code means that there's an issue to check. He did check but since the car runs fine assume it's okay...
  5. bisco
    52,388
    could be the speed sensor or harness i suppose. looking at it won't fix it
  6. ski.dive
    967
    245
    *What are some of the things on 'Drivers side rear brake area'
    **That will cause the BRAKE- ABS- VSC- Warning Lights to come On
  7. Brian1954
    2,402
    962
    What is the trouble code that the mechanic found?????? Then you will get some help.
    How hard is it to provide the actual trouble code?
    Danno5060 likes this.
  8. bisco
    52,388
    low tyres pressure
  9. highmilesgarage
    493
    182
    Kansas City
    that's a question you ask to your mechanic... we are not psychic here
    Brian1954 likes this.
  10. rjparker
    10,504
    6,593
    Most standard code readers won’t read hybrid specific codes but…(Places Carnac hat on)
    1. Rear hub speed sensor is a possibility. This code is standard and any scanner could read. There are several detailed codes such as a wiring open or sensor failure. On this car the rear sensors are built into the rear wheel bearing hub. If bad the whole hub is replaced. A moderate expense.
    but… those sensors rarely go bad and even more rarely come and go…so
    2. Brake Booster (Master Cylinder/abs/skid ecu combo) does go bad rather commonly. Has been known to be intermittent. It also has specific codes only a hybrid enabled scanner will read. Expensive to fix as it is only available from Toyota.
  11. ski.dive
    967
    245
    The mechanic read 'the Code'= [ he did not tell me the 'code number' ]
    All he said was- that the 'code' had something to do with 'Drivers side Rear Brake'
    He thoroughly checked the 'Drivers side rear brake' and found nothing wrong.
    He said, that in the near future, I should flush and replace the brake fluid.
  12. Brian1954
    2,402
    962
    You can always ask the mechanic and come back and post what the trouble code is.
  13. highmilesgarage
    493
    182
    Kansas City
    in the near future, don't go back to that mechanic.. and you always ask for the code to research it yourself (and avoid shops scamming you)
  14. ChapmanF
    18,538
    That "something to do with" part is what needs to be replaced by the pages (usually several) of info you find in the repair manual when you look up the actual code. That's why we harp on getting the code, not the "that has something to do with" story.
  15. Merkey
    Merkey Active Member
    319
    291
    Birmingham, Michigan
    I had the same problem with mine. It was the wheel speed sensor. Not an inexpensive repair at the Toyota dealer.
  16. highmilesgarage
    493
    182
    Kansas City
    repair at the dealer is not inexpensive, that kind of fixes can be done in a shop (or DIY) relatively cheap.. just look for a good mechanic that shows you the actual codes.. or best buy a code reader, it will pay off in just 1 visit to the dealership. Just don't buy those cheapo obd2 readers..get the Autel.
  17. mr_guy_mann
    mr_guy_mann Senior Member
    4,087
    1,997
    NJ-USA
    Could be something electrical with the wheel speed sensor. Could be something hydraulic with the brake lines or wheel cylinder. Could be something internal to the brake system actuator assembly.
    The thing about guessing games is that they can keep going on & on. Without more specific clues (the actual codes), we can't give any meaningful advice.
  18. Mendel Leisk
    41,900
    Just for giggles, check if there's a dangling electrical connector at the aforementioned back brake.
