Tire maintenance, hub caps in the way
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by pasadena_commut, Nov 20, 2024.
  1. pasadena_commut
    pasadena_commut Senior Member
    2,456
    735
    Southern California
    Short form: what tire gauges and pumps (manual or electric) do you use to maintain the tires on this vehicle? Without having to remove the hub caps. Bonus points for tools that a reasonably spry elderly person could manage
    Long form:
    I'm currently visiting my elderly mother and even more elderly stepfather. The TPMS light is on in her 2012 Prius. My step father would normally have taken care of this, but he is even older and recent physical problems have put an end to his days of driving and working on tires. Their tire gauge accidentally went away with his car when they gave that to one of the grand kids. OK, thought I, tires are just tires, and pulled the tire pressure gauge and Serfas bike pump out of my 2007 to use them to check and/or fill any tires which are low. (Assuming it wasn't a failed TPMS unit in a tire.) Nope, the hub caps foiled me at every step. First the tire gauge, the kind that presses on perpendicular to the stem, wouldn't seal because there was no angle where it wasn't obstructed by the hub cap. Tried to hook the bike pump fast release on and it wouldn't clear the hub cap, which once again blocked access. The hub cap on the 2nd generation isn't very different from that on the 3rd generation, but the tire stem sticks up far enough out of the notch that these two devices attach without problem, whereas on her car it is down in the notch too far for them to fit. Later stopped at an O'Reilly's and bought their house brand dual headed pencil gauge
    https://www.oreillyauto.com/detail/c/xtra-seal/xtra-seal-10-to-120-psi-tire-gauge/xts0/151031
    which did seat nicely, and showed that at least that one tire was low - 28 PSI on the front. Yikes. (This model gauge is hard to read though, because it has such a large range the values for this car are just a fraction of a mm apart.) I could get a valve extender (should have done that while at O'Reilly's) to use with my pump for now, but that won't be a solution for her going forward. I need to find an electric tire pump that she can hook up, set the pressure, and let it run until it stops - without removing the hub caps. My mother is pretty spry for her age, but there is no way she will be pulling off the hub caps to maintain her tires. Picture a 90 year old doing this:
    Hers has different hub caps than in the video, these:
    Thanks.
    #1 pasadena_commut, Nov 20, 2024
  2. Mendel Leisk
    40,975
    I was trying to air up Tesla 3 tires. The car's had 2 sets of wheel covers, ostensibly identical but the tire valve opening on the most recent set was just slightly smaller, to were I couldn't get my pump's air chuck in. Resorted to extenders:
  3. ASRDogman
    ASRDogman Senior Member
    7,424
    3,867
    They have valve stem extenders. Different sizes. You could look on ebay, or a tire store
    might have them.
    A wide flat blade screwdriver will get the WHEEL covers off. Depending on how your
    fingers are, you can grab the edge and give it a yank...
  4. ChapmanF
    17,740
    I grab mine at the inner 'spokes' and yank, plenty of room for my fingers, unlike at the edge.
    But I don't have to do that for routine checks and airings, because on my 2010 the covers don't interfere with my air chuck.
  5. Mendel Leisk
    40,975
    Mom's 90 though.
  6. pasadena_commut
    2,456
    735
    Southern California
    Found an old bike pump in the corner of their garage with a smaller chuck. That one fit on if the hose was aimed at the hub, but the lever was so stiff I was afraid of breaking the stem from the force. Now I just need to find an electric pump with a chuck that size or smaller, with a lever that an old lady can move, and she should be good to go.
  7. ASRDogman
    7,424
    3,867
    ORRRRR.... you can leave the wheel covers off....
  8. BiomedO1
    3,133
    1,663
    SacTown, Ca
    As long as the tire isn't flat, She can gently drive it to the nearest Les Schwab or American Tire to get it taken care of - might have to wait a bit if they're really busy - but they do that for free. America Tires does flats for free too; not sure about Les Schwab.
    Hope this helps....
  9. pasadena_commut
    2,456
    735
    Southern California
    There is an America's Tire about a mile away, so that would be a good option. Les Schwab only has a single store in the Bay Area, and driving from San Jose to Fremont to fill the tires seems a little excessive. Thanks.
    I did suggest to her that this would be easy if the hub caps could go, but she doesn't like the look of the bare wheels (they have lost hub caps before).
    I'm thinking of getting her one of these from Home Depot:
    Husky 120-Volt Inflator H120N - The Home Depot
    It has a "set the pressure and it fills to that and stops" option, with a nice digital display. Apparently it isn't the most reliable device in the world, and can only run for 5 minutes at a time, but should still be OK for topping off the tires if they do it more or less regularly. She is OK plugging in devices, whereas keeping one of the battery powered inflators charged is a bit of a stretch for her, and plugging something into the power socket of the car, and possibly blowing the fuse, is never going to fly.
    BiomedO1 likes this.
  10. BiomedO1
    3,133
    1,663
    SacTown, Ca
    Just make sure that valve stem clamp will fit - otherwise get some valve stem extensions on those tires.
    Good Luck....
  11. pasadena_commut
    2,456
    735
    Southern California
    My understanding is that leaving valve stem extensions on TPMS stems is a bad idea, at least if the car is going to be driven at any appreciable speed. No problem using them temporarily to check pressure or add air, and they can stay on just to roll around a shop. Probably not such a great idea to use them on regular tire stems either. I know they are common on trucks, but in those cases the original stems are steel, as are the extensions, and they even sometimes have rubber or other supports added to take the strain when they are spinning at high speeds. Like this one:
    Inner Dual Tire Valve Stem Extension Stabilizer 2-1/2″ Round for Accur - Tire Supply Network
  12. rjparker
    9,878
    6,089
    I bought this $52 tire inflator which can inflate 4 tires without overheating on its lithium battery or run from a Prius 12v port. It has setpoint and shuts off at the set pressure. It is also small and lightweight.
  13. ASRDogman
    7,424
    3,867
    there are extentions you screw onto the stem. They are only about an inch in length.
    Usually plastic.
    Here is a start: 4PCS Metal Tire Wheel Valve Extension Extender Cap Stem For Car Truck Van | eBay
    Tire Valve Stem Extensions for sale | eBay
  14. ASRDogman
    7,424
    3,867
  15. pasadena_commut
    2,456
    735
    Southern California
    Is the tire end of that tube a quick release of some kind? I can never tell in the pictures if it is a screw on hose or not. The ones with a lever it is obvious that they are a quick release.
    Another thought, I believe the TPMS units are not OEM. Perhaps the OEM TPMS units have longer stems, so that the tip is not so deep into the hub cap, and they are easier to get to? My 2007 is right next to my mother's 2012 and the thickness of the hub caps does not seem very different, which would put the variation at the TPMS units.
  16. pasadena_commut
    2,456
    735
    Southern California
    So, I measured the tip of the quick release on that Home Depot pump and it was slightly smaller than the one on the old bike pump, so it would fit. Bought it and brought it home and showed it to her and my mother decided even this simple device was going to be too much, so she will be getting her tires filled up elsewhere.
  17. ASRDogman
    7,424
    3,867
    Why don't you just check them for her yourself every few weeks?
    Give you rmother peace of mind.
  18. pasadena_commut
    2,456
    735
    Southern California
    It is a 400 mile drive, each way.
  19. ASRDogman
    7,424
    3,867
    Okay, I thought you we close....
    I sent you links to the extenders. Get her a battery powered inflater.
  20. pasadena_commut
    2,456
    735
    Southern California
    Her husband always used to do the tires. I think she has decided that at this age she would rather pay someone else to set the pressure in the tires than start doing it herself. There has been other delegation recently, like hiring a window cleaner instead of doing that, and that was a task she actually used to do.
    ASRDogman likes this.
