Tire Size and Calibration Puzzle ?
Discussion in 'Gen 5 Prius Main Forum' started by Templeton, Nov 18, 2024.
  1. Templeton
    Templeton Member
    272
    82
    usa
    2024 Prius Prime
    SE
    This might be all academic anyway.
    I was just looking around online at most of the major tire retailers. There do not seem to be any all season tires available in 205/60 R17... dang.
  2. PriusCamper
    PriusCamper Senior Member
    12,701
    5,135
    Pacific Northwest, USA
    Sure would be nice if Toyota Techstream had a way to change how those numbers are processed based on tire and wheel size all the way down to amount of wear on the tread. Of course most people just drive their car and don't want to worry about any of that.
    Templeton likes this.
  3. PriusCamper
    12,701
    5,135
    Yeah... Gen5 Prius designers made it real hard to have plenty of options for tire shopping. But maybe in time the market will catch up to demand for odd sizes?
  4. rjparker
    10,093
    6,260
    The only vehicle speed pulse comes from the skid ecu which calculates it from the abs sensors. The speed on the display is adjusted by another ecu and is transmitted along with accurate odo data to the combination meter (display) using the can bus.
    Many decades ago, a transmission based mechanical cable or sensor was used for the speedometer.
    In this simplified Toyota dealer description, the ECU being discussed is the skid/abs ecu.
    What Is A Wheel Speed Sensor And Why Is It Important? | Toyota Parts Center Blog
  5. kiwiscoot
    kiwiscoot Member
    60
    30
    Christchurch New Zealand
    2019 Prius Prime
    For Android phones Ulysse speedometer app.
  6. Gokhan
    Gokhan Senior Member
    6,153
    2,432
    Paramount CA
    My 2021 Prius Prime Limited with OEM Dunlop tires shows exactly 2 MPH higher at all speeds on the speedometer than the actual speed.
    One of the best ways to measure the actual speed is the Google Maps navigation app on your phone, which uses the GPS.
  7. kiwiscoot
    kiwiscoot Member
    60
    30
    2019 Prius Prime
    Yes my New Zealand 2019 model is about 4kph higher than actual speed, so corresponds to your 2MPH higher. Mine is not on OEM tires but same size as OEM. Makes it easy as I just drive on cruise control set to 5kmh higher than the posted speed limit.
    Gokhan likes this.
  8. thetoys
    thetoys Member
    28
    Toronto, ON
    2024 Prius Prime
    XSE Premium
    At highway speeds, Prius Prime Speedometer reading 3% higher than Waze on OEM 19”.
  9. darkstar3274
    darkstar3274 Junior Member
    46
    2022 Prius Prime
    yes I only got summer tires Bridgestone Turanza T005 in 205/60R17...so far still ok even in sub-50 and low 40s...unsure how this will be once it gets into 30s consistently
  10. darkstar3274
    46
    2022 Prius Prime
    used Galileo GPS speedometer app today speed exactly matches the car display-low speed to high speed - it kept up with the displayed speed no issues on the speedo
    17 inch wheels from SE with 205/60R17 Turanza on XSE Premium...
    thetoys likes this.
  11. rjparker
    10,093
    6,260
    The roadside radar speed displays are more accurate than gps.
  12. Gokhan
    6,153
    2,432
    Paramount CA
    Both the GPS and roadside radar displays always show exactly 2 mph lower than my 2021 Prius Prime Limited speedometer at all speeds.
    If you have a good phone with good GPS reception and enable accurate location, it should easily be accurate within a fraction of an mph.
  13. Trollbait
    12,507
    Those are rounded, though GPS could too depending on device and app. i also wouldn't put it past a municipality setting theirs to display high.
    If you want precision with whole number digital displays, best to use km.
  14. mva
    mva Member
    130
    77
    B.C. Canada
    2024 Prius Prime
    SE
    I wouldn’t go any smaller diameter than the stock 195/60/17’s because my SE is already really low to the ground.
    reservoirblue likes this.
  15. Templeton
    Templeton Member
    272
    82
    usa
    2024 Prius Prime
    SE
    Yes, I was more thinking of 205/60R17s on an SE (prime). But I did not want to make my speedometer even more inaccurate than it already was. But going to slightly more accurate is, I would think, good.
    #35 Templeton, Nov 22, 2024
  16. Mendel Leisk
    41,334
    Going to 205/60R17 yields a theoretical OD of 26.7". IIRC that's identical to the stock 19" tire's OD?
    This site is good for checking:
    Tire Size Comparison
    #36 Mendel Leisk, Nov 22, 2024
  17. Templeton
    Templeton Member
    272
    82
    usa
    2024 Prius Prime
    SE
    Thanks, I looked at that.
    That is why I was wondering if the calibration on everything (Speedo, Odometer, etc.) was more based on the 19" wheels/tires, or if it was more based on the 17" wheels/tires, or if it was specific to the different trims (with different wheel sizes).
  18. Gokhan
    6,153
    2,432
    Paramount CA
    The spec for the outer diameter will tell nothing about speedometer calibration. You need to look at the spec for the revolution per mile.
    Different tire models with the same tire size will have different revolution per mile.
  19. Templeton
    Templeton Member
    272
    82
    usa
    2024 Prius Prime
    SE
    Thanks, yeah, I looked at that too before I even started this thread
    That is why I was wondering if the calibration on everything (Speedo, Odometer, etc.) was more based on the 19" wheels/tires revs per mile spec, or if it was more based on the 17" wheels/tires revs per mile spec, or if it was specific to the different trims (each with different revs per mile spec).
    Mendel Leisk and Gokhan like this.
  20. Gokhan
    6,153
    2,432
    Paramount CA
    The calibration of the speedometer on my 2021 Prius Prime Limited with Dunlop Enasave 01 A/S tires is perfect—always 2 mph higher than the actual speed in the entire speed range—which means that they got the revolutions per mile exactly right within a few revolutions.
    If the revolutions per mile differs more than 0.5% on the 17" vs. 19" tires, I would guess that their speedometers were calibrated differently. Chances are that they used the OEM-tire spec when they calibrated them, as tires from different manufactures can differ greatly on the revolutions per mile.
