Brake noise at stop
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by donroyledbetter, Jul 1, 2023.
  1. donroyledbetter
    donroyledbetter Junior Member
    Brakes make horrible clunking screeching sound at the moment before complete stop and on release of pedal.
    Any one here with the same problem? A solution?
    This is my first post to PriusChat.
    You can hear the noise on YouTube by searching: @toyotafrenirumorosiscricch2355
    The noise started shortly after 7/21 new car purchase and has continued for 20K since. Has been to the dealer EIGHT times: they checked, they inquired to Toyota, they lubricated, they changed discs and pads, they reprogrammed a couple times. no change. We have appealed to Toyota Europe several times, they refer us back to the dealer who does not seem to care and points the finger at Toyota. The last reply from Toyota Europe was a patronizing: "The noise is caused by friction".
    I was very happy with my first new 2010 Prius, this one has been a total disappointment. That Toyota PR about relaxing warranty is BS.
  2. Afra
    Afra New Member
    Birimgham
    Hi brother i was searching on google and i found this prius chat. The same problem i am facing now i changed brake pads twice but problem is same. I seen you post from last year. Just want to ask is problem solved and what was the issue. Whats your suggestion for me. Thanks
  3. a2058
    a2058 Junior Member
    52
    Westchester, NY
    2019 Prius
    XLE AWD-e
    That sounds like the dust shield is rubbing against the rotor or something like it. I would take the wheels off and inspect for clearances. When I did the wheel bearings, I accidentally bent the dust shields too much and the car would make that type of noise, worth checking into.
