AISIN WQT-800 inverter pump failing within a year?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Oranjoose, Nov 20, 2024.
  1. Oranjoose
    Oranjoose New Member
    Indiana
    A year ago December, I posted saying a cheap inverter pump was failing after a couple months ( Any way to keep inverter pump alive once it starts croaking? | PriusChat ) , and everybody said I should replace with OEM, and so I replaced it with an AISIN WQT-800.
    11 months and merely 3000 miles later, this AISIN pump is making that hallmark wheekoo wheekoo electronic pumping sound my original Prius pump made before it failed.
    When I put in the AISIN, I bled the air out of the lines and mostly swapped the coolant (a hose clamp failed and drained most of the coolant, but I didn't drain the rest out of the bottom).
    Should I completely drain the coolant and fill with new coolant? Would that rescue this pump? I feel that this pump is failing very early for its reputation.
    If the coolant is in fact contaminated with particulates and such, would replacing the coolant do much to prevent this pump from failing, or should I just replace it (again) AND change all the coolant?
    The reservoir is turbulent in ACC mode (orange light, engine off), and the pump is making its normal hum, indicating the pump is still working. It's just begun to do the electronic croaking (I've heard it now 5 or so times) if at a stop light after driving above 50mph (at least that seems to be the pattern).
  2. dolj
    dolj Senior Member
    8,528
    4,327
    Wellington, New Zealand
    Just to be clear, the AISIN WQT-800 is not OEM. It is also possible that it is not a genuine AISIN WQT-800 either. Depending on where it was purchased, it could very well be a counterfeit.
    Whether you replace it is up to you but it won't likely "rescue" your pump.
    Brian1954 likes this.
  3. Oranjoose
    Indiana
    I ordered it from Rock Auto and it was the model that members of this forum were recommending.
    Are you saying that once it starts making that wheekoo wheekoo struggling pump sound that it's pretty much inevitable that it's on its way out?
  4. mr_guy_mann
    mr_guy_mann Senior Member
    4,080
    1,995
    NJ-USA
    Do not know. I ordered a pump from the Toyota dealer 65k ago. Haven't had any problems.
  5. dolj
    dolj Senior Member
    8,528
    4,327
    Are you sure you're hearing that sound from the pump and not the coolant control valve, which is nearby the inverter coolant pump?
  6. T1 Terry
    T1 Terry Active Member
    929
    491
    Are you sure it isn't pump cavitation? That is not only a pump killer, it can be a component kill as well. Usually caused by loss of cooling system pressure and dilution of the coolant allowing it to either boil because of temp, or because there is a restriction on the intake side dropping pressure and in turn, dropping the boiling point. Have you replaced the hoses on the suction side of the pump, they can suffer with being sucked in to the point they restrict flow, exaggerating the problem even further .......
    T1 Terry
  7. Oranjoose
    Indiana
    My coolant control valve is indeed failing (intermittent code P1121), but does it make the same noise? My inverter pump failed summer 2023, resulting in the red triangle inverter overheat. The sound that the inverter pump was making before that sounds exactly like the sound that's happening now, and it's happening in the same scenarios (occasionally after driving over 50mph for 10 minutes and then coming to a stop).
    I haven't gotten the P0A93 code yet for a failed inverter coolant pump.
  8. dolj
    dolj Senior Member
    8,528
    4,327
    The CCV's common failure sound is similar to a top-loading washing machine agitating or an HDD constantly seeking (only much louder). There are quite a few posts in the Gen 2 forums where people have uploaded a sound file demonstrating the sound.
    If that's the sound you hear, it is the CCV, not the ICWP.
  9. DrummerDave
    DrummerDave Junior Member
    Asheville NC
    AISIN is the OEM pump.
  10. ChapmanF
    18,458
    It's possible for multiple things to be true at once, like (1) Aisin may be the manufacturer from whom Toyota obtains the pumps they sell, and (2) it would take substantial inside knowledge to find out whether the Aisin-branded WQT-800 is or isn't identical in all respects, QA acceptance thresholds, and so on (except for price, of course) to the units they supply to Toyota.
  11. T1 Terry
    929
    491
    There is also the tolerance acceptability limit, below that level of manufacturing excellence, those that didn't make it are known as seconds, then there are levels of these seconds as to how far below spec they are, the buying price reflects this, so a 3rd level second may be cheap, but it is well below the primary buyers quality requirement.
    Truely good manufacturers, don't sell their seconds, hey are immediately destroyed, right there at the testing phase, others cut their losses by selling their rejects ....
    T1 Terry
    douglasjre likes this.
  12. pasadena_commut
    pasadena_commut Senior Member
    2,776
    831
    Southern California
    In the late 1970's I worked some summers for a company which made, among other things, through hole component LEDs. There was a batch that failed QA. They had a temperature spec of something like -25 to 85 °C and they were not quite bright enough at the upper limit. So there was a big box of defective components which would eventually be sent to I have no idea where for disposal. There was a wink wink understanding that we could take a handful or two for our own hobbyist projects, we just couldn't resell them (or those projects with those components in them). This was long before the internet, I'm not sure how one would have gone about grey marketing them at the time. Ad in the PennySaver maybe?[/QUOTE]
  13. pasadena_commut
    2,776
    831
    Southern California
    The OP might want to use a mechanic's stethoscope to listen right on the pump and then elsewhere. I would suggest either unplugging the cooling fans by the radiator or pulling the fuse for them (if it doesn't disable something else) before trying this. The only other moving component is the belt for the mechanical water pump and that is pretty far away and so shouldn't be a safety hazard.
