U0293 Lost Comm w/ Hybrid Powertrain Control Module
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by tracy ing, Feb 17, 2018.
  1. fa1984dy
    fa1984dy New Member
    Au
    Hi Patrick . My car is Prius 2011 . It overheated . Was a lot of noise coming from the coolant reservoir . I left it to cool down and there was no leakage . So i decided to drive it again . Then it stalled . And all the gears on dash were blinking . And code say lost communication with hybrid power terrain control module. Do you have a suggestion please ?
  2. fa1984dy
    fa1984dy New Member
    Au
    Thank you for letting me know . Cheers
  3. Nphra
    Nphra Junior Member
    Hello Do you know which fuse did you pull out ?
  4. Nphra
    Nphra Junior Member
    Where is these fuses fuses: 20A HEV, 15A AM2.
    Cannot find in 2011 Prius 3rd gen.
  5. dolj
    dolj Senior Member
    8,434
    4,285
    Wellington, New Zealand
    You should create a thread in one of the Gen 3 forums including the background and symptoms of your problem, along with any DTCs (diagnostic trouble codes) you have.
    Beware, what works for the Gen 2 might not work the same as that for the Gen 3.
  6. Brian1954
    Brian1954 Senior Member
    2,165
    843
    South Central PA, USA
    This is a thread for a Gen 2 Prius. You have a Gen 3 Prius, which can be different.
  7. Brian1954
    2,165
    843
    Nphra does have a thread created in the Gen 3 forum, https://priuschat.com/index.php?posts/3493606
    dolj likes this.
