Only getting about 30 mpg 2010 Prius with sunroof
Discussion in 'Gen 3 Prius Fuel Economy' started by Prius2010driverdude, Nov 25, 2024.
Tags:
  1. Prius2010driverdude
    Prius2010driverdude New Member
    Los angeles
    Hello. I bought the car used. I recently had the main battery replaced. I thought this would improve the mpg but it hasn’t made a difference. The smaller battery was replaced about a year ago.
    thanks for your help and let me know if you need more details.
    52,335
    mileage?
    service records?
    is it a new oem hybrid battery?
    any trouble lights?
    air filter
    throttle body
    dragging brake
    plugs
    injectors
    coils
    tyres and pressure
  3. Prius2010driverdude
    Los angeles
    Hi. It’s a refurbished battery with I believe 30,000 miles on it. No warning lights. Everything else seems to be fine shocks, tires etc
  4. Eddie25
    Eddie25 Active Member
    501
    212
    MI
    First thing I would do is jack up the rear (there's a convenient rear-center jack point) so the tires were off the ground and test for wheel drag. Spin the wheels by hand and they should spin around a few times on their own, at least. There can be issues with calipers not retracting properly.
  5. bisco
    52,335
    driving style?
    terrain?
    climate?
  6. BiomedO1
    4,059
    2,136
    SacTown, Ca
    I got 30 mpg in my 76 Honda civic 5-speed w/1.5L engine. IMHO; you've got issues, so take it to a Prius specialist before dumping any more money into it. FWIW; most ICE cars of similar size, built after 2010 will do 35-40 mpg - without the added expense and weight of a hybrid system.
  7. Mendel Leisk
    41,850
    I think bisco meant the miles on the odometer. That’ll display for 30 seconds or so, every time you shut down.
  8. bisco
    52,335
    yeah, not expecting any more answers
