Toyota Parts Black Friday Sale - 25% off - Nov 26 thru Dec 2
Discussion in 'Gen 5 Prius Main Forum' started by Hammersmith, Nov 26, 2024.
  1. Hammersmith
    Hammersmith Senior Member
    2,328
    2,383
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Just a heads up to anyone looking to stock up on OEM parts & supplies. I believe this is the biggest sale of the year. There are a couple other 20% weeks/weekends, but I think this is the only 25%.
    Choose a dealer that has the max 31% discount, and your combined discount will be 48.25%. As long as your total comes to $75 after the 31% but before the 25%, you'll also get free shipping.
    Standard site: autoparts.toyota.com - only 25% off
    Example of a 31% off*: autoparts.lewistoyota.com - 48.25% off most things
    *There are many, so don't feel you have to choose this one. I only use it because it's closest 31% off to where I live.
    #1 Hammersmith, Nov 26, 2024
    clearcoated, wnrsm, Templeton and 3 others like this.
  2. Hammersmith
    2,328
    2,383
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    FYI, a full year of gen5 maintenance supplies will cost between $100 and $120 plus tax using this sale.
    2x oil filter - 90915-YZZN1
    2x oil drain plug gasket - 90430-12031
    10x quart TGMO oil (no discounts for buying by the case) - 00279-16QTE-01
    2x left wiper insert - 85214-08050
    2x right wiper insert - 85214-0E130
    1x engine air filter - 17801-24040
    1x cabin air filter (regular or premium) - 87139-YZZ83 or 87139-76020
    Lewis:
    Total w/regular cabin filter = $96.68+tax
    Total w/premium cabin filter = $118.28+tax
    You don't necessarily need to change air filters every year or wiper inserts twice a year, but I wanted to show worst case. Of course if you drive more than 10k miles a year, then you'd need 3 filters/gaskets and 15 quarts of oil.
    Winston Smith, Templeton and Gokhan like this.
  3. rjparker
    10,558
    6,623
    Yes it’s a good time to order oem parts. I have saved big in the past during these sales.
    #3 rjparker, Nov 26, 2024
  4. Illini Al
    Illini Al Junior Member
    Bolingbrook, IL
    2024 Prius
    XLE AWD-e
    Note that this sale also includes Accessories.
    The last sale several weeks ago did not.
  5. Winston Smith
    Winston Smith Active Member
    408
    284
    OH
    2024 Prius
    LE AWD-e
    Many thanks.
    I stopped changing my own oil some years ago, but picked up the junk for three changes after your post.
  6. Templeton
    Templeton Active Member
    327
    118
    usa
    2024 Prius Prime
    SE
    Many thanks also!
    It was interesting, I was looking for the provided part no. for the left wiper insert (85214-08050), but a few toyota part sites showed it as incompatible with a 24 prius? What gives? Or, is this just a case of a change of part numbers?
  7. Hammersmith
    2,328
    2,383
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Probably a part number change. I've bought quite a few and they've all fit. I'm pretty sure I got the numbers from the MicroCat parts catalog. You can also call a dealer's parts department to confirm.
    The autoparts.toyota.com section for Prius wiper blades is a mess. Between the 2023 and 2024 Prius and Prius Prime versions(4 combos in total), there's only a single insert labeled as a confirmed fit. 85214-0E130 for the 24 Prime. The 23 Prime and both regular Priuses have no confirmed compatible parts listed. I'm chalking it up to bad data entry.
    Templeton likes this.
  8. Templeton
    327
    118
    usa
    2024 Prius Prime
    SE
    Another question, when are the other times of the year that these toyota associated parts sites have comparable (like the 20% off) sales? Thanks.
    daisy555 likes this.
  9. Hammersmith
    2,328
    2,383
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    I'm learning them as we go. I think there are 20% off sales around Memorial Day and Labor Day. Maybe there's a 4th of July sale? I think some are only a weekend, while others (like the Black Friday) are a week.
