Prius V road warrior build
Discussion in 'Prius v Accessories and Modifications' started by Ford Galaxie, Nov 26, 2024.
  1. Ford Galaxie
    Ford Galaxie Member
    63
    29
    Rome, GA
    2014 Prius v wagon
    I’ll start with this.
    Built out of 3/4” plywood, some hardwood pine, fiberglass filler.and your standard fare home improvement store black utility carpeting.
    To get the fit as close as possible, I used a contour gage to make up some patterns out of some old crappy plywood and cardboard. Fitted the patterns together and with some trial and error came up with some templates and transferred it to some decent material for the build.
    I built this in two sections. The first section was to have a flat floor. The second section is the cabinet that fits on top of it, using Titebond.
    It fits correctly enough to the contours in the car that it doesn’t even need to be fastened, but there’s a power inverter that’s going in it. I used one. Just one. It mounts to a seat belt threaded insert in the vehicle.
    #1 Ford Galaxie, Nov 26, 2024
  2. Ford Galaxie
    Ford Galaxie Member
    63
    29
    Rome, GA
    2014 Prius v wagon
    Victron Energy Phoenix 1200 watt inverter. I chose this for several reasons.
    1. Pure sine wave.
    2. True 120vac output
    3. Maintains true 120 vac output under load
    4. Switched on by remote trigger
    5. Bluetooth- monitor the inverter via phone/tablet app.
    6. Highest efficiency in its class.
    External marine socket on the front, with an Isobar inside, all 12 gauge.
    2 gauge power and ground to the inverter with 125 amp breaker.
    The inverter is mounted to the cabinet floor using 10/32 brass inserts.
    #2 Ford Galaxie, Nov 26, 2024
  3. bisco
    51,851
    looks great! what is it?
    Mendel Leisk and Ford Galaxie like this.
  4. Ford Galaxie
    Ford Galaxie Member
    63
    29
    Rome, GA
    2014 Prius v wagon
    That’s a great question. I suppose I should have stated the purpose of this thing. It replaces the rear passenger side seat with:
    1. A place to store things.
    2. A place where I can charge batteries for portable tools.
    3. To house the inverter.
    4. A flat floor from front to back, which also serves as a place to lay down a foam mattress.
    5. Provide 120vac up to 10 amps via a marine plug on the front.
    more pics to come.
    #4 Ford Galaxie, Nov 26, 2024
  5. Ford Galaxie
    Ford Galaxie Member
    63
    29
    Rome, GA
    2014 Prius v wagon
    #5 Ford Galaxie, Nov 26, 2024
  6. Ford Galaxie
    Ford Galaxie Member
    63
    29
    Rome, GA
    2014 Prius v wagon
    The rear of the vehicle has the Prius Offroad coil springs which added about 2.5-3” of lift in the rear. I replaced the shocks with a set of KYB’s for a regular Gen 3 Prius- they’re slightly longer than the Prius V shocks and are a direct fit otherwise.
    Airlyft airbags installed.
    Kurt 2” hitch with an external4 plug connector- truly plug and play setup. I have a cover for it, however the hitch also serves as a repellent for various Kia, Hyundai and Stellantis/FCA products. I'm on the third bumper cover on the third gen car. I now leave the hitch in that one too.
    #6 Ford Galaxie, Nov 27, 2024
    vvillovv likes this.
  7. Ford Galaxie
    Ford Galaxie Member
    63
    29
    Rome, GA
    2014 Prius v wagon
    The office. Rubber floor mats are a must have. Pull them out and hose them. Cable management is also important as having to deal with loose cables or finding them will just pi$$ you off. I don't want to deal with it especially in the middle of the night, if I need to take a meeting, when its raining, when you want to relax, etc..
    For you geeks, that's a 13" Dell Lattitude tablet with an i5, 16GB of memory, 16:10 display and a 256GB internal SSD- more than adequate for my needs and doesn't require a lot of power to run it- I'm using it for business, not for World of Warcraft. I also have an IPAD Pro and an IPAD mini that will fit in there as well, but for business stuff on the road, I really need a Windows based machine. I just hotspot it to my phone when away.
    Switched 12v recepticle on the back of the console, on a relay, from the battery.
    External 120vac from the cabinet.
    #7 Ford Galaxie, Nov 27, 2024
  8. Ford Galaxie
    Ford Galaxie Member
    63
    29
    Rome, GA
    2014 Prius v wagon
    The front has the Prius Offroad 2” aluminum spacers. Pirelli P-Zero 255/45R18’s on 18x8 wheels. These were pulls from a late model Mustang and have a slightly more negative offset (5mm outward).
    This is probably the tallest and widest tire that wil fit on this vehicle without rubbing, I also removed the inner fender liners for additional clearance.
    This vehicle did come with the optional LED headlights and also has the squirters for the headlights.
    The turn signal lights are removed from the bumper and relocated into the headlight assembly, using one of the two pairs for the parking lamps.
    The driving lights are JDM glass bullets fitted with an H11 headlight LED bulbs. Mounted on some brackets I made up out of aluminum as they are not a direct fit for a Prius V. They still retain adjustment. I also added a relay and a switch as I prefer to use them without the restrictions the original circuit has.
    #8 Ford Galaxie, Nov 27, 2024
  9. Ford Galaxie
    Ford Galaxie Member
    63
    29
    Rome, GA
    2014 Prius v wagon
    I had bought this 2014 Prius V Five for cash "as-is" under my LLC from an estate sale in the summer of 2022. It was a very low mileage one owner vehicle that had meticulous maintenance and service and came with the documentation to prove it. It was also optioned with everything short of "The Technology Package (the glass roof/nav assist package)". However it did have some scars. I spent some money having it spot painted and straightened out by one of the dent doctors in the area (small business owners have a great quid-pro-quo system among themselves). It's now a dent free car and I have gone through pains to keep it that way- black cars especially just look like crap with dings and dents.
    The front bumper cover was tore up as well as most of the plastic covers underneath. Both driving lights and turn signal lights were either broken and/or filled with water. The bumper bar was also bent, but fortunately the hood was fine and there was no tweaking of the frame rails. I bought a used aluminum bumper bar off of Ebay.
    I bought a new front bumper cover from Toyota and painted it in single stage acrylic urethane using some universal Chevrolet Truck black- and there ain't a speck of dirt in it. I also removed all the plastic skirting and use a Prius Offroad aluminum skid plate in its place. The cover is now retained with only 4 bolts. This works out quite well when encountering those late night armadillos and possums as there is now a lot of flex in the cover. Since it had them originally and I liked them, I also bought a new set of chrome driving light rings and a chrome grill bar to replace the broken ones. In place of the Toyota emblem, I cut a piece of aluminum and wrapped it in carbon fiber to fit in the emblem hole.
    The hood had some road rash and some dings. Worked out the dings (fairly easy to do with an aluminum hood, providing you can get to them from the backside) and I wrapped it in carbon fiber wrap. Keeps it from gaining new ones as well.
    I also installed a pair of Auxbeam 100 watt CREE LED offroad lights behind the lower grill, drilled and tapped to the rear side of the aluminum bumper bar using brackets I fabricated out of .125" aluminum L channel. Seeing at night through the mountains and on dark rural roads is no problem anymore.
    #9 Ford Galaxie, Nov 27, 2024
  10. Dan H
    Dan H Junior Member
    44
    22
    Miami FL
    2015 Prius v wagon
    This looks like an awesome project. What are you doing about interior lighting?
  11. Joele3
    Joele3 Active Member
    135
    200
    Bay Area
    I cant stop staring at the sub boxes. Where do I find specs ?
  12. Mr Cleeb
    Mr Cleeb Junior Member
    Nevada
    2017 Prius v wagon
    I believe you can get another arm for a second monitor to swing from the passenger headrest over to you in the rear driver's side seat for dual monitor.
  13. Ford Galaxie
    Ford Galaxie Member
    63
    29
    Rome, GA
    2014 Prius v wagon
    So here’s a business trip out in Ohio in February at scenic Russell’s Point. Pretty comfy sleeping. Weathertech window shades, a 600 watt heater on a temperature controller powered off the inverter, with the vehicle temp set at 67 kept it comfy even in the single digit nights.
  14. Ford Galaxie
    Ford Galaxie Member
    63
    29
    Rome, GA
    2014 Prius v wagon
    I couldn’t find any. However I got lucky when I found one somebody on EBay who made one- the left one I bought from a guy on eBay who had made one for his Prius V. It got me in the ballpark as I cut it apart and reworked it so that the box clears the cargo lid and I extended it down to the floor.
    A few months I decided that if one was great, then two should be even better (it’s not). The right side one I scratched using the cargo interior panel as a template- layed it up in masking tape and layed fiberglass over it.
    The goal was to keep them from eating up any floor space- I win. Each cabinet has a JL Audio 10w0 2 ohm sub, in parallel (for a 1 ohm load) running off a cheapie NVX 500 watt pocket rocket amp- and I truly believe that it probably makes every bit of that fairly distortion free. Lord knows I’ve made every excuse to try to blow that amp up as an excuse to get something nicer, but I gave up. Truly a great little amp.
    #14 Ford Galaxie, Feb 25, 2025
    Joele3 likes this.
  15. Ford Galaxie
    Ford Galaxie Member
    63
    29
    Rome, GA
    2014 Prius v wagon
    The original dome light with an LED bulb in it works adequate for me. I did install two pod lights in the rear hatch lid. I also keep a rechargeable flashlight handy.
  16. Dan H
    Dan H Junior Member
    44
    22
    Miami FL
    2015 Prius v wagon
    How do you like the weathertech window shades? Do you have them all around and do they black out the interior? Also are you leaving the car on or are you running off the 12 volt or an additional 12 volt? I ask because I tried sleeping in freezing weather once and the car kept turning on and off waking me up every few minutes to keep the car warm. I didn't use a separate heater though. Also what additional benefit, over the Prius offroad springs, do you get from the Airlyft airbags? Sorry I have a lot of questions, but you look like you are doing it right. Thx
  17. Ford Galaxie
    Ford Galaxie Member
    63
    29
    Rome, GA
    2014 Prius v wagon
    In addition to privacy - they do blackout the vehicle- the Weathertech shades insulate the vehicle quite a bit. The windows are also ceramic tinted - 35 percent front, 5 percent rear and the tailgate window blacked out- I have a rear view mirror camera, which adds the benefit of knowing when someone is behind you when all the shades are in.
    On nights below freezing I set the temp control to 67 degrees, a/c off ( no compressor constantly cycling) and turned on the 600 heater AC heater. The heater is on a temperature controller plugged into a 1200w inverter. Weathertech shades on all windows including the windshield. this is good if the temperature isn’t any colder than about 16 degrees. Below that I just run the car heater at 68-69 degrees. It’ll use over twice as much fuel this way - a bit over 2 gallons over 10 hours
    Above freezing, I can get by running the 600 watt heater with the vehicle heater off, but moisture on the windows is a problem, so I keep a window cracked. use about a gallon every 8-10 hours.
    I occasionally pull a trailer. I did a trip with one for about 700 miles with about 1200 lbs ( including the enclosed trailer) with the Prius off-road rear coils, with no sag. Since I had already bought the airlift airbags, I installed them anyway afterward (I was too lazy to do it before this trip) . It probably didn’t need them, however I keep about 25 psi in them as it firms up the rear and minimizes sway. The Prius Off-road springs ride no better or worse than the original coils- I can gain some ride height and carry virtually anything without sag, I’d say Eric at Prius Off-road did his homework- highly recommend.
    As it is right now, it weighs about 45 pounds more than it did without modifications- I gave up one seat, halved the weight of the hybrid battery pack by going to a lithium hybrid battery, with the subs and the trailer hitch making back up the weight. The 18” Mustang wheels with the Pirellis actually weigh 4 lbs less each than the original 17’s did with Coopers.
    #17 Ford Galaxie, Mar 3, 2025
  18. Ford Galaxie
    Ford Galaxie Member
    63
    29
    Rome, GA
    2014 Prius v wagon
    In addition to privacy, the Weathertech shades insulate the vehicle quite a bit. On nights below freezing I set the temp control to 67 degrees, a/c off ( no compressor constantly cycling) and turned on the 600 heater AC heater. The heater is on a temperature controller plugged into a 1200w inverter. Weathertech shades on all windows including the windshield.
  19. Dan H
    Dan H Junior Member
    44
    22
    Miami FL
    2015 Prius v wagon
    thx for the info
