Valvoline Hybrid ATF
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by AzusaPrius, Aug 21, 2024.
  1. AzusaPrius
    AzusaPrius Senior Member
    2,230
    930
    Going to be replacing my transmission fluid with this and will be adding a magnetic drain plug. 20240821_172046.jpeg 20240821_172100.jpeg
  2. Hector Jerezano
    Hector Jerezano New Member
    2022 Prius
  3. Mendel Leisk
    41,873
    I don't think Toyota's authorized anything other than Toyota ATF WS. They caution against using anything else, using the word "damage".
  4. AzusaPrius
    2,230
    930
    I have not done the fluid change yet.
    It gets very cold where I live and so I rather wait for warmer temps to do it.
    But I should have had it done already when I got the stuff to do it and the temp was good, just had other things to do.
    I have front wheel hubs I have not put on yet either.
    I saw a review online from someone with a prius who used it with no problems and I also contacted Valvoline to make sure it was safe and they said it is safe to use on a prius.
    Hector Jerezano likes this.
  5. Simply Driven
    Simply Driven Junior Member
    Tucson AZ
    Any updates on this?
    #5 Simply Driven, Oct 3, 2025
