Need Ideas For a Mattress For Two People
Discussion in 'Living Life in a Prius' started by Pjfelony, Nov 9, 2024.
  1. Pjfelony
    Pjfelony New Member
    Trying to find a comfortable mattress that’s fits in a 2019 Prius
  2. Gorgonzola
    Gorgonzola Member
    40
    27
    New Hampshire, USA
    2024 Prius
    LE AWD-e
    Finding a mattress that will fit two people may be difficult given the dimensions of the cargo area. I believe the distance between wheel wells in a Gen4 is roughly 36 inches, so that would be your primary limiting factor. Inflatable double mattresses are typically 54 inches wide. Some lightweight camping mattresses may be slightly narrower, but the narrowest camping double that I could find is 40 inches (the Big Agnes Rapide SL Insulated sleeping pad measures 40” x 72”). I would be interested to hear thoughts from others on this topic — maybe someone else has found a mattress that works?
    Another option you might consider buying a large piece of memory foam or polyurethane foam and cutting it to fit the shape of the cargo area… Just an idea
    Sawah likes this.
  3. JimLudden
    JimLudden Member
    89
    36
    Taos, NM
    2024 Prius Prime
    At least in Seattle there was a foam shop that would cut a foam mattress to any size/shape you want.
  4. BiomedO1
    4,112
    2,155
    SacTown, Ca
    IMHO, an inflatable mattress with a built-in pump, battery powered - of course, would be the way to go. It'll conform around the strut assemblies, unlike your hips or back. You would be able to adjust it's firmness, but you'll need to deal with temperature drops = deflation. Ergo the built-in pump, if you need it to firm-up in the middle of the night. Easy to stow away, so it doesn't look like a "bum-car", if people look in.
    Hope this helps....
  5. hyo silver
    hyo silver Awaaaaay
    15,272
    1,604
    off into the sunset
    2025 Prius Plug-in
    XSE Premium
    The way you say 'comfortable' makes me think you mean something other than a pair of light, easy to stow, self-inflating camping mattresses, laid over a yoga mat or two.
  6. vvillovv
    vvillovv Senior Member
    4,324
    1,512
    NY
    just 3 words (y)
    One of these
    after you get the matress figured out adding a Stalwart lightweight heated blanket
    might make things a tad more comfortable
    12 volt powered available and Target and Amazon
  7. bisco
    52,371
    reported
  8. Wrecit
    Wrecit Active Member
    177
    113
    Pittsburgh
    2001 Prius
    I
    Ok disappointed that this only got half an answer. It’s old so probably 2 late but as mentioned an air mattress is my recommendation. A Colman or similar style full size works great and with a little help while inflating will form fairly comfortably around wheel wells. I was 50 and wife was 48 and we were tent camping and I swear the weather man said it wasn’t going to thunderstorm
