Prius Prime SE Wheel Center Cover Cap
Discussion in 'Gen 5 Prius Accessories and Modifications' started by specc, Nov 28, 2024.
  1. specc
    specc Junior Member
    2024 Prius Prime
    SE
    I took off the wheel cover and realized my car is missing the center cover cap. So I added this one instead. What do you think ? I feel the wheel design is a lot better than the wheel cover and it's also winter time soon need to cover the wheel bearing with something.
    Agent337 and Eddie F like this.
  2. Mendel Leisk
    41,784
    If it stays in that's all that matters. It'll definitely prevent rust-up. Pretty sure there's a Toyota centre cap. Are the 19" rims bare with a centre cap? That'd probably fit, and maybe more secure. For that I'd check with a dealership parts department; trying to use Toyota USA's parts site now is hopeless/
    #2 Mendel Leisk, Nov 28, 2024
  3. mowgli
    mowgli New Member
    Massachusetts
    2024 Prius Prime
    XSE Premium
    Part 42603-52170 seems to be the OEM center cap for every model and trim of Toyota since 2016
  4. Perfectpacman
    Perfectpacman Junior Member
    84
    24
    United Kingdom
    2024 Prius
    ----UK----
    They're either 56mm or 60mm.
    I guess you could measure with a Vernier gauge.
  5. KMO
    KMO Senior Member
    2,002
    728
    Finland
    2023 Prius Prime
    FWIW, the caps for my European non-factory Prius accessory 17" wheels were 42603-42170. But who's to say whether they're different, or if they were whether they'd be more likely to be a better fit for the factory 17" wheels.
    Could just be a different colour (they're black).
    #5 KMO, Nov 30, 2024
  6. specc
    specc Junior Member
    2024 Prius Prime
    SE
    Oh it will definitely stay. I made it with my 3d printer. I wanted something less flashy.
    Winston Smith and Mendel Leisk like this.
  7. Perfectpacman
    84
    24
    United Kingdom
    2024 Prius
    ----UK----
    The part number says this is for the 93-96 Camry?
  8. KMO
    KMO Senior Member
    2,002
    728
    Finland
    2023 Prius Prime
    According to? When I searched for the part number, main thing that showed up was the bZ4X.
    (As mowgli suggested, there probably aren't a huge number of different cap parts in use.)
  9. Perfectpacman
    84
    24
    United Kingdom
    2024 Prius
    ----UK----
    My mistake .....
    Not enough posts yet to link.
    Says the following -
    Make/Model/Year:
    Toyota Corolla 2017-2024
    Toyota Prius 2016-2024
    Toyota Yaris 2015-2020
    Product Specifications:
    Product ID: C75207
    Product: Center Cap (Single)
    Material: Plastic
    Finish: Black With Chrome Emblem
    Size: 2 1/8 Inch Diameter
    OE Part Number: 42603-52170
  10. Templeton
    Templeton Active Member
    321
    114
    usa
    2024 Prius Prime
    SE
    Nicely done!
    Any chance that you could share the CAD file? And any suggested resolution and infill percentage settings? What material did you print with? Thanks.
  11. Templeton
    321
    114
    usa
    2024 Prius Prime
    SE
    Any chance that you could share the CAD file, or maybe a link to where you found it? Much appreciated.
  12. Eddie F
    Eddie F Junior Member
    Windsor, Canada
    2024 Prius Prime
    SE
    I bought and tried OE Part Number: 42603-52170 on my Prime SE 2024 - it falls right through!!
    3D model would come in handy, specc.
    Mendel Leisk and Templeton like this.
  13. Mendel Leisk
    41,784
    Someone can maybe measure the hub opening inside diameter carefully with a caliper and post?
    Prodigyplace likes this.
  14. Perfectpacman
    84
    24
    United Kingdom
    2024 Prius
    ----UK----
    It's 60mm on the original 17" alloys.
  15. Mendel Leisk
    41,784
    Another factor is the groove location inside the bore, how far back it is from the front face. That’s crucial for the caps jaws to lock properly.
  16. Coreeee
    Coreeee New Member
    Southern California
    You're going to tease us like that and not post the file?
    Templeton likes this.
  17. MScelery
    MScelery Junior Member
    83
    24
    Mississippi
    Any chance you could either post the file or charge me to print a set?
  18. Robert Dubois
    Robert Dubois New Member
    Quebec
    2025 Prius Plug-in
    You can find Toyota center caps for Prius in STL file format for 3D printer. Per example, thingiverse site,
    Toyota Prius/Corolla Center Wheel Caps #42603-52170
