Prius heater not getting hot enough!
Discussion in 'Gen 3 Prius Main Forum' started by Chester92, Nov 30, 2024.
  1. Chester92
    Chester92 New Member
    27
    Los Angeles
    I bought a 2011 prius with 180k miles in the summer. Car runs amazing! Did a tuneup and changed the water pump / thermostat with aisin brand. Its about 40 degrees now and I went for a drive but the cabin temperature is not getting hot enough at the hottest setting HI. Its warm but not hot enough to have to turn it off of full blast.
    I can hear some air bubbles under the dash when idling so my guess is air trapped in the system? I followed the coolant bleeding procedure by filling to the B line and maintenance mode squeezing the hoses etc. I notice that on the front defrost setting without AC on and the HI setting on the AC lines are cold as if the AC is on. Could this be a result of a bad climate control setting?
    Been reading up and I need some help from you guys. Will update you as we go through this!
  2. Tombukt2
    13,778
    2,495
    I think in that car and even maybe in my generation too when you put that defrost on it automatically puts the compressor in the mix not like it's air conditioning but still it's on that's why you're feeling the cold turn the defrost off heat on high not 85 but HI and let it run a few minutes like that I can't imagine you're running around all the time with the defrost on usually I only need that a couple minutes in the morning and as soon as the cabin gets warm yeah anyway. But bubbles are yes are a bad thing so now when you filled it up to be and you've done the driving and what not has it fallen down to the full mark? If so that air should just work its way out I mean I don't know how long this has been you've done all this work but generally a few drive cycles I don't mean 4 minutes. Should get it
  3. StarCaller
    StarCaller Senior Member
    1,284
    733
    Cedar Crest, NM, USA
    If your car has air trapped in the cooling system, it will likely result in no heat because the air bubbles prevent the coolant from circulating properly through the heater core, which is responsible for generating warm air in your car cabin; essentially, the air pockets block the heat transfer, leading to cold air blowing from the vents.
  4. ASRDogman
    ASRDogman Senior Member
    7,997
    4,061
    Did you fill the system quickly? That's the issue.
    You should drain the system, and save the coolant!
    Then, SLOWLY, about a cup or two at a time, fill the system. Wait 5-10 seconds,
    then add more. You'll hear the coolant draining, and the air being pushed out.
    It will take you longer to fill it, but you won't have air in the system.
    And yes, fill to the B line. Start the car and let the engine run until it shuts off.
    The level should go down to the full line, more or less. Add coolant to just about the full line.
    And you're on lever ground, right?
    Then drive the car a mile or so trying to keep the engine running the whole time.
    Then park the car and let it cool. Check the coolant level. Top off as needed.
    Filling too fast doesn't allow the air to be pushed out, it just caused air pockets.
    This happens on other vehicles too. Filling slowly and a little at a time allows a gap in
    the hose and lines so the air can be displaced.
  5. Mendel Leisk
    42,210
    My first thought is stop-leak product was installed by seller. See also the following postscript.
    #5 Mendel Leisk, Nov 30, 2024
  6. ASRDogman
    7,997
    4,061
    PS: NEVER NEVER EVER PUT THAT SO CALLED STOP LEAK/HEAD GASKET SEALER IN
    THE COOLANT SYSTEM!
    IT DOES NOT WORK! IT ONLY CLOGS UP THE COOLANT SYSTEM....
    Danno5060, kamrul and Mendel Leisk like this.
  7. BiomedO1
    4,461
    2,350
    Left Coast
    You need to fully purge the air from your cooling system.
    Why did you change the water pump & thermostat? Was the car overheating and are you currently monitoring the ECT?
    It would be difficult to purge the air from your cooling system, if exhaust gases are being constantly pumped into your cooling system. Ergo the stop leak in the cooling system, so the previous owner could sell the car. The auto parts store has a chemical dye that will react to exhaust gases in your coolant. It's not a 100% accurate test, but it'll give you an idea of what your dealing with.
    Sorry.....
  8. Chester92
    27
    Los Angeles
    It was showing me the temp light when climbing up long hills so i replaced those parts and its been great for about 500 miles so far. Now i needed to use the heat and I noticed it not heating fully.
    I will try to purge the air from the system first by removing the back "high hose" with that black "vent removed new version" and let you know how it goes. Seems like thats what im hearing anyways
    Brian1954 likes this.
  9. ASRDogman
    7,997
    4,061
    It's extrememly rare exhaust gets into the coolant for the Prius.
    By the time that happens, the engine is wasted.
    And it's easy to get rid of the air in the coolant system. Best NOT to get any in if the first place.
  10. Brian1954
    Brian1954 Senior Member
    2,622
    1,037
    South Central PA, USA
    Why did you change the water pump? Was the engine overheating?
    It is possible that the new Aisin water pump that you installed is faulty.
  11. ASRDogman
    7,997
    4,061
    See post 4
  12. Chester92
    27
    Los Angeles
    Well it seems like its fixed but i wanted to make sure over these next few days. I removed the upper hose towards rear of engine near that vent tube that got discontinued and air and coolant came out
    Mendel Leisk and Brian1954 like this.
  13. StarCaller
    1,284
    733
    You're welcome / ;)
  14. Mendel Leisk
    42,210
    Good to know that's still effective, vent or not.Our 10 has the white plastic clap you can partially unscrew, allowing air to vent, say during refill after a coolant drain. It seemed effective when I did our coolant change in 2020. Just left it open while filling, till I saw solid coolant flow.
    I suppose you could splice in a t-connection with a screw cap on the side spout. They're referred to as "Flushing Tee".
    Tombukt2 likes this.
  15. Chester92
    27
    Los Angeles
    Problem has come back :( I drove home after about 20 mins of hwy driving and the hose going to the thermostat was not hot. Wondering if the thermostat is the problem or am i not seeing something else it could be?
  16. ASRDogman
    7,997
    4,061
    See Post #4.....
    Have you replaced the thermostat?
    If the hose to/from the thermostat is NOT hot, obviously the coolant isn't flowing.
    After replacing it, with a TOYOTA thermostat, SEE POST #4.....
  17. Chester92
    27
    Los Angeles
    They had aisin brand but I had everything replaced. Maybe I need to make sure its TOYOTA brand?
  18. Tombukt2
    13,778
    2,495
    I don't think the two brands of the pump are a huge issue Asian and Asian and their toy that's one of Toyota's companies or it was I don't know what the status is right today but something along those lines now Toyota has a lot of companies they use that they don't own and that they don't have parts made predominantly for them they make parts for everybody just like nippondenso makes all the electric from my Italian scooters. Not having enough water in the system in air trap will cause the same problem water won't move through the system because you can't pump air everything looks like it's full You're getting a little squirt when you take pressure off the cap and all of that but really nothing's happening so you got to make sure you are super full of water coolant etc and that it has a chance to move or else it's not .
  19. Chester92
    27
    Los Angeles
    I swapped thermostats but its the same problem
    The lower radiator hose does NOT get hot. The upper overflow hoses on the coolant degas bottle get hotter than the lower hoses which is throwing me off. Anything else i can check? I can hear the water pump working and it has been tested that it works and it is very hot to the touch. The thermostat housing itself is very hot as well but the lower radiator hose coming out of the thermostat is not hot.
  20. Chester92
    27
    Los Angeles
    After 10 mins of driving the coolant is pressurized in the degas tank however i still have no strong heat in the car. The top hoses are very hot but bottom hoses are cold
