Wireless Carplay problem, 2024 Prius LE, iPhone 14 pro max
Discussion in 'Gen 5 Prius Audio, Electronics and Infotainment' started by David W. Griffin, Dec 11, 2023.
  1. David W. Griffin
    David W. Griffin Junior Member
    I had another unusual CarPlay issue. I got kicked out with another "interruption in connection" and I got my phone out to maybe reboot it to see if that had any effect. There was an error box from the app and when I clicked OK and then clicked reload on the car it actually came back (which was a first). I have been rebooting my phone more often, not sure if it has had an effect or not.
  2. David W. Griffin
    I'm still seeing the problem. In the first, it crashed when I got home. In the other, it crashed after startup when the map screen froze. The first time I rebooted both the phone and the car in that order and it reconnected. In the second I had to press the power/volume button for the screen (middle screen) till it turned off and then turned it on. Then it connected. This is really debilitating. Toyota really needs to work on stability for carplay or at least work with Apple to make it better.
  3. Martin Green
    Martin Green New Member
    Westerly RI
    2024 Prius Prime
    XSE
    I have found that if I remote start the car with the phone, then get in the car; the apple car play will never connect. I have to turn car off and on again to get it to connect.
  4. Civiceg94
    Civiceg94 Member
    59
    44
    Nyc
    Same issue i am running into. Even if i dont and going in and out the car multiple times it will not wireless connect anymore
  5. Richard CabezaDeBaca
    Richard CabezaDeBaca Junior Member
    United States
    2023 Prius
    2023 Prius LTD. I have Bluetooth connectivity problems on a regular basis. I am frustrated by this and have had issues with mapping when the wireless connection is lost. Is Toyota going to address this ?
  6. Sharol
    Sharol Member
    161
    74
    Kansas, USA
    2023 Prius
    I have a '23 limited. It connects fine to my Samsung Galaxy. HOWEVER, there is another thread on androids, and some people have problems (my husbands Samsung e10 for instance), so I don't think it is just a problem with Apple phones, just some of them. We have discovered that if an app is open on the screen of the phone (Sirius for example), the phone won't connect to the car. No idea why.
