Android Auto disconnecting
Discussion in 'Gen 5 Prius Main Forum' started by Argyros, Dec 12, 2024.
  1. Argyros
    Argyros Active Member
    274
    141
    2023 Prius
    This has happened since new, but lately I've had to reconnect my Android Auto by going into the menu and hitting the connect button almost every time I re-enter the car.
    It keeps forgetting the connection.
    Anyone having this issue, and how have you fixed it?
  2. dolphinsil
    dolphinsil New Member
    2024 Prius Prime
    XSE
    Yes. I haven't investigated it further yet.
  3. Argyros
    274
    141
    2023 Prius
    Still awaiting help
    ..thanks in advance
  4. BiomedO1
    3,130
    1,660
    SacTown, Ca
    Have you tried deleting the phone from the car's system - then reinstalling. Sometimes things get messed up in the hand-shaking protocols and this is the result. Also double-check your phone's security settings, to allow the car to automatically connect. Since you need to manually reconnect on the car side, I'm assuming the issue is on the car side protocols.
    Hope this helps....
  5. Argyros
    274
    141
    2023 Prius
    I'll try that, BioiMed01, and let you know if it works. Thanks!
    BiomedO1 likes this.
