Replace the 12v battery? 2013 PIP
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by 13PIP91326, Dec 10, 2024.
  1. 13PIP91326
    13PIP91326 Junior Member
    17
    2013 Prius Plug-in
    Hello experts!
    So I got that water pump and thermostat replaced so happy there. I drove it back 45 miles to Hybridpit in Buena Park CA and all went well.
    So fast forward to 1 week later, took the car on a short ride to the store early morning and suddenly...
    - lost power
    - light on the dash was the "red steering wheel and exclamation point"
    - was able to slow-crawl to a parking spot
    - adding that there are no dtc codes
    I pulled over and called for a tow truck. In the wait, I disconnected and reconnected the 12v and the car fired back up and was able to drive it back home.
    I tested the 12v and it tests 12.2 on standby and 11.5 (ICE not running) w AC and headlights on. And adding that its a 4yr factory battery, the car is not driven as much and the weather is getting colder.
    Like to get your thoughts if you also think its best to just get a new 12v battery. I may go get it at costco; they seem to be best priced. The dealer sold me this one for $220 in 2020 and they want $280 for a new one today minus -25% prorate. Costco is $177 for an AGM.
    Thank you once more.
  2. rjparker
    9,828
    6,067
    I would not replace the better oem battery after 4 years without load testing it first.
  3. bisco
    51,486
    if it is the oem 12v, replace it. what scanner are you using?
  4. 13PIP91326
    17
    2013 Prius Plug-in
    Using the Veepeak.
  5. Brian1954
    Brian1954 Senior Member
    1,979
    777
    South Central PA, USA
    What app are you using with the Veepeak?
  6. 13PIP91326
    17
    2013 Prius Plug-in
    Using
    CAR SCANNER ELM OBD2
    Over IOS
    checks 130+ DTCs
  7. Brian1954
    1,979
    777
    The reason I was asking is because if you have warning lights on the dash, it means that there are trouble codes that need to be read. But you stated that there were no codes. The app you used is a fairly good app to read codes.
    13PIP91326 likes this.
  8. 13PIP91326
    17
    2013 Prius Plug-in
    The OBD and app is 4+ years old and it’s paid for itself a few times over. Thank you for the input.
    My PIP has become the spare car and it probably prefers to be used more. great car/ had never changed the brakes/ $70 oil changes at 5k/ looks great/ high tech at its time/ HOV sticker but exp now/ / I’d like to keep it forever but maybe time for someone else to take it.
  9. bisco
    51,486
    that's what i did with mine. great car but the head gasket was suspect
  10. Mendel Leisk
    40,919
    So many variables there. Measure voltage with the car off, first thing in the morning, with a multimeter. Either at the under-hood jump-point, or directly at the battery posts, should make much difference. If it does make a difference, you've got a loose connection somewhere.
  11. rjparker
    9,828
    6,067
    A simple and free load test is the way to evaluate the battery. Voltage after sitting is not definitive since an excessive parasitic draw causes the same thing.
  12. 13PIP91326
    17
    2013 Prius Plug-in
    Thank you for the time guys.
    Plan to take the 12v to autozone this week for that free test just to make sure.
    Fast forward to yesterday. I have the Dr Prius app too and ran a Hybrid battery test to see the current “condition” of the big battery (a year ago I think it’s said good at 80%)
    This time it threw on the Check engine light and Check Hybrid system. DTC is POD58. Will research it more this week as I see a few definitions for it online. (Something about O2 sensor in bank 2 or low voltage somewhere)
    Appreciate any intel if you guys are able to grace me again.
  13. rjparker
    9,828
    6,067
    If running the test caused the code, I would clear it and wait for a check engine. It is likely not valid. The Dr Prius capacity test is a guess anyway you look at it.
  14. vvillovv
    vvillovv Senior Member
    4,320
    1,505
    NY
    Dr Prius Hybrid Battery tests work way differently in our plugin prii than the they do in non plugin prii.
    It would have been very easy to have set a code in the Plugin trying to follow the testing procedures that were developed for non plugin prii.
    I've gotten through both tests at least once each, BUT, it's not easy, even after learning what the tests are looking for and how to get the tests to complete as least once ( without throwing a code or two ) like you experienced.
  15. 13PIP91326
    17
    2013 Prius Plug-in
    Update fellas: I ended up replacing the ECU and cleared all the codes and car is running very well again. I maybe selling it now that its back to its original self.
  16. Paul Gregory
    Paul Gregory Senior Member
    1,876
    467
    Alberta
    2024 Prius Prime
    XSE
    I replaced mine after 5 years. It didn't seem to hold a charge anymore.
    Gen 1 ? I always considered my 2012 Prius Plug in a Gen 3.
  17. rjparker
    9,828
    6,067
    Only here is a 2012 labeled a gen1 because it was the first prius plugin.
    Merkey and 13PIP91326 like this.
  18. Brian1954
    1,979
    777
    Which ECU did you replace? There are about 24 different ECU's in your Prius.
